Thread: Stepper - ballscrew loading
22-06-2012 #2
Not quite sure what you're asking - do you want to know how much force the motor can apply if the Z-axis pushes straight down into the material?
If so, then the answer is dependent primarily on what speed the motor is running at and clearly what motor/driver you are using. For sake of argument lets say it's a 3Nm motor on 70V, operating below the corner speed (about 880rpm = 4400mm/min), which is realistic as the Z-axis rarely goes very fast. Under those conditions the torque is a 2Nm.
Formula for driving force, F=T*2*pi*e/L where T is torque, L is pitch (m/rev) and e is efficiency (around 90% for ballscrew).
So with 2Nm on a 5mm pitch ballscrew, remembering that lead is in meters, you have; F=2*2*pi*0.9/0.005=2262N
We should factor in the weight of the Z-axis, but as you can see ballscrews/leadscrews can apply a huge amount of force so this is negligible in comparison. So in short don't stick your fingers under it!
Does that answer your question?
Looking into a ballscrew, not sure if I should buy. Help
By oldmam4m80s in forum Lead Screws, Nuts & SupportsReplies: 21Last Post: 28-07-2017, 10:15 PM -
WANTED: Ballscrew and nut
By D-man in forum Items WantedReplies: 8Last Post: 30-08-2013, 04:25 AM -
Ballscrew Woes, help please!
By jonbabbz in forum Lead Screws, Nuts & SupportsReplies: 9Last Post: 21-04-2012, 12:16 AM -
Where to get C3 & C5 Ballscrew
By AdCNC in forum General DiscussionReplies: 10Last Post: 10-08-2011, 06:56 PM -
Loading Calculator for Z axis
By Ross77 in forum Linear & Rotary MotionReplies: 7Last Post: 28-07-2010, 09:57 PM
