Thread: Ambitious newby
    brett, its allways a good idea to let people have a look at your drawings so they can pull them to bits :) try not to take any criticism personaly... most of us have had a go at re-inventing the wheel and if nothing else, the attempt is fun and beats watching eastenders :)
    your crank looks to have no meaningful counterbalance
    your inner cylinder ports wont pull as much volume as your outer ports because of the con-rod obstruction (not sure if that would be a massive issue)
    the crank will have a very small footprint in that slot (not sure if that will last long)
    iv not seen a two stoke with injection, i think understand the issues you are trying to solve with injecting but im also assuming that the reason we dont see it is to do with the optimum injection timing being during induction so it would follow that the exaust port would still be open during injection and you would still be left with the old issue of raw fuel escaping before the exaust port closes (im sure two srokes are being phazed out for that very reason, terrible imissions)
    im reasonabley sure you could machine most of those parts with a lathe & cnc mill (im not overly confident on your design at this point though)
    I guess I assumed an opposed engine didn't really need counterbalance. If it does I have no idea how to design it. As far as the obstructed ports, I also don't really know if that would be an issue. I suppose I could flare the port and manifold on the inside chambers if I need to. I haven't put a lot of work into the crank design as of yet. I've only really been working intensively on the drawings a few months now so there are no details set in stone by any means. This is really just a concept drawing at the moment. I'm not saying I'm ready to get started building it. I'm just your average ADHD kid who needs to have 12 things going on to not get bored.
    Lives in East Lothian, United Kingdom. Last Activity: 6 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,969. Received thanks 368 times, giving thanks to others 9 times.
    Quote Originally Posted by brsanko View Post
    The opposing piston/rod assemblies will counter balance each other, however the crankshaft itself will still have offset masses flying around at great speed unbalancing things.
  1. Newby needs help
    By Gregor in forum Tool & Tooling Technology
    Last Post: 07-01-2014, 03:33 AM
  2. RFQ: Ambitious Bicycle build project needs help
    By Psycholist666 in forum Projects, Jobs & Requests
    Last Post: 16-03-2013, 12:10 AM
  3. NEW MEMBER: Newby from London, Canada
    By Leadfootin in forum New Member Introductions
    Last Post: 25-12-2010, 01:11 PM
  4. NEW MEMBER: Newby Introduction
    By Sides in forum New Member Introductions
    Last Post: 06-09-2010, 10:47 PM
  5. NEW MEMBER: Birmingham, newby.
    By Malc in Brum in forum New Member Introductions
    Last Post: 23-11-2008, 06:28 PM
