    What control software are you using.? Like Micheal says it very much sounds like the machines setup wrong.
    It's not uncommon for the Z axis to be set to a different number of steps to the X & Y axis in the control software.?
    Usually this is because the Z axis screw use's a smaller pitch so requires more steps to cover the same distance. . . . So if for instance your X & Y use 10mm pitch screws and the Z Axis use's 5mm then it will move exactly half the distance of the X & Y for the same number of steps so possibley some ones used the same settings for all Axis.?
    Easy 2min fix but first if you can give a few more details on the drives and how they are setup regards micro stepping then it may be better to change the micro stepping at the drive or just change steps setting in the control software.?
    If your not sure how they are setup then some good pics of the drives will help along with make and model. Also the control software used IE Mach3, EMC2 etc
    hello
    I am using Mach 3 the steps are set at 160 and all axis threads are the same. the G code is showing the correct depth ie Z-7
    I can say that this a sudden occurrence during this particular job
    Quote Originally Posted by dinasblu View Post
    So are you saying it's been working OK then suddenly done this.?
    If yes has it just done it without any changes to Mach.? By that I mean not changing any motor tuning settings or any thing.?
    Can you post the G-code file so can take a look.
    Edit: Can you give following details of machine so we can verify steps per is correct.
    Thread pitch or turns per inch along with any ratio if geared.
    Drive model and micro stepping set to IE 400,800,1600 etc could show on drives as 1/2 or 1/4 - 1/8 etc or 4X 8X 10X
    Confirm steppers are 1.8deg (200 steps per rev)
    Thank you everyone who replied to me with your advice and ideas. I have changed the steps per in motor tuning
    from 160 to 320 and it is now cutting to the required depth. Thank you once again for your help.
  1. RFQ: 4 and 5mm steel plasma / laser cutting required, can send sheetcam files
    By nobby in forum Projects, Jobs & Requests
    Last Post: 29-04-2014, 12:36 PM
  2. Critique required on y-axis design.
    By Spedley in forum Gantry/Router Machines & Building
    Last Post: 06-05-2013, 09:17 PM
  3. Not cutting perfect right angles and sticking on Y axis ?
    By Fivetide in forum Milling Machines, Builds & Conversions
    Last Post: 10-12-2012, 09:41 PM
  4. Farnborough based CNC Setter/Operator required (5 Axis)
    By Simon_Cheung in forum Opportunities Available & Sought
    Last Post: 30-11-2012, 04:30 PM
  5. End mill depth 'stop' rings
    By HankMcSpank in forum Tool & Tooling Technology
    Last Post: 24-02-2010, 02:03 AM
