Thread: Auto zero Z axis problems
	04-07-2012 #13
Most likely this was due to a corrupt .xml file.
Make a copy of it asap, and next time you experience any type of strangeness, delete the .xml in the Mach3 folder and replace it with the backup copy. Much easier than doing a clean install.
I've had my .xml file go bad twice in the last 18 months. In both cases, the machine would no longer home. It would move a fixed amount away from the switch and stop, every time. I don't know if anything else was affected, as I didn't run the machine, since I couldn't home it.
Z AXIS, big tex blue screen and auto tool sensor Problems
By Tomnewry in forum Artsoft Mach (3 & 4)Replies: 11Last Post: 01-01-2014, 09:01 PM -
What Spindle / Auto Tool Changer?
By Chaz in forum Tool & Tooling TechnologyReplies: 11Last Post: 01-08-2013, 10:35 PM -
Boxford VMC190 Retrofit Problems, axis sounds very rough
By mikegolding in forum Boxford Vertical MillsReplies: 5Last Post: 09-06-2013, 09:11 PM -
any one know about auto lube systems?
By graffian in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 02-03-2009, 05:52 AM -
Auto spindle lock
By Robin Hewitt in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 30-08-2008, 08:15 AM
