Thread: Timing Belts
    You can have belts made to any length you want, that what I did with mine. I use a local bearing company so try your nearest decent bearing place.
    Regards the belt design and heres one way using 2 idlers on plate that with adjustment for motor. All same size pulleys for 1:1 on my machine I go 2:1 with 5mm pitch screws using 24T on screws 48T on motor but you can use any size pulleys that suits. 15mm wide belts for me.
    Edit: My machine doesn't use this system it use's short belt from motor to screw then long belt between screws. This is because my screws are 1300mm centres so suits it better.
ID:	6440   Click image for larger version.
ID:	6441   Click image for larger version.
  2. The Following 4 Users Say Thank You to JAZZCNC For This Useful Post:
  3. Quote Originally Posted by JAZZCNC View Post
    Images of Jazz's set up - link below (posted when I was asking a similar question!)
    http://www.mycncuk.com/forums/showth...xis-CNC-router
    Within reason - using too small pulleys can stress the belt too much or risk leaving not enough belt teeth engaged with the pulley. I avoid using less than 15T pulleys for this reason.i
  5. #4
    If you look I said any belt that "suits" and obviously too small giving wrong tooth engagement wouldn't suit would it.?
    Quote Originally Posted by boldford View Post
    Am I missing something but, isn't it possible to locate the motor between the two lead screws and fit two pulleys to the motor to drive two belts?
    Yes it is and that's how I did it first time but found it hard to get even tension on each belt.! It also means having the screws offset or one machined longer or like in my case where I hadn't allowed for this when machined due to originally going to use slaved motors screw extensions needed making.
    The way I have it now isn't pretty but it works very very good and super reliable and easy to swap ratios.!
ID:	6450   Click image for larger version.
ID:	6451   Click image for larger version.
ID:	6452   Click image for larger version.
ID:	6453   Click image for larger version.
  6. #5
    True, hence I clarified for anyone who does not know that a small pulley not be suitable.
  1. FOR SALE: Timing belts HTD 336 3M
    By viz in forum Items For Sale
    Last Post: 07-03-2013, 08:22 AM
  2. Advice: Timing Pulleys and Belts
    By Mad Professor in forum Belt Drive, Pulleys & Timing
    Last Post: 24-06-2012, 12:30 PM
  3. Found Timing Belts
    By GeorgeD in forum Gantry/Router Machines & Building
    Last Post: 14-07-2010, 07:36 PM
  4. Timing belts for motors
    By action-kat in forum Belt Drive, Pulleys & Timing
    Last Post: 12-01-2010, 01:39 AM
  5. Source for XL timing belts and pulleys
    Last Post: 20-08-2009, 01:21 PM
