    If we are going just on avatars then get the daughter fixed up with Audio Andy, match made in heaven.............
    John S -
    Cheers John now we have turned into match maker as well !
    Bench is varnished, I have a power breaker fitted and the pooter’s installed –with XP SP3. So the Cat is on the bench, but the serial cable was male to female and I need a male to male as I’m not installing the hardware that came with it.
    I need to drills some big holes in the bench to feed the cabled down and move my lamp to the middle, but I’m not paying £20 to use it once so I’ll nip to my dads who no doubt has one from the 1960’s in drawer in his workshop somewhere.
    Down side is the hardboard on the bed is held down with what look like Philips screws and the heads are mangled, so somehow I need to get that off to diagnose the tilted bed problem.. well I’m off to CPC in the morning for a serial cable. Then hopefully have a bit of a trial run with her.
ID:	6807   Click image for larger version.
ID:	6806   Click image for larger version.
    Ralph Waldo Emerson
    Looks good. Soon be cutting.
    Bruce
    The more I know, I know, I know the less. (John Owen)
  5. #15
    Fivetide
    Just buy a gender changer for the cable you have it should be cheaper.
    One thing to check with shop purchased cables is to check that all pins are connected (voice of experience )
  6. #16
    PS11270 - PRO SIGNAL - LEAD 25 WAY DM TO 25 WAY DM 2M | CPC
    I'm hoping they are all connected Unit Price: £2.91 (£3.49)
    Ralph Waldo Emerson
  7. Quote Originally Posted by Fivetide View Post
    Sadly not, if you'd clicked on 'further info' :
    CS17361, CSLEAD106/9 wiring: 1-1, 2-2, 3-3, 4-4, 5-5, 6-6, 7-7, 8-8, 20-20
    What you needed was CS17364 @ Unit Price: £2.06 (£2.47) (PS11274 - PRO SIGNAL - LEAD 25 WAY DM TO 25 WAY DM 1 | CPC)
    CS9115, CS17364 wiring: all pins connected 1-1, 2-2 etc.
  8. #18
    Damn !! i was wrong on 2 accounts then DOH ! because I actually needed a serial M to Serial M as the control box is Serial F ... grrrrr I get close then kapooom.. another thing wrong.. oh and the water pump dosen't seem to work either .. have to find another one of those.. oh well I'm still kean though lol :)
    Ralph Waldo Emerson
  9. Quote Originally Posted by Fivetide View Post
    Do you mean a 9 pin D to 9 pin D? When you say Serial M to Serial M do you mean straight through connections or DTE-to-DTE (crossed Tx/Rx, CTS/DSR). You need to be specific... :)
  10. #20
    Yeah 9 pin D .. lol well I hope so .. look alot like a vga.. i'll have it sorted by tomorrow
    Ralph Waldo Emerson
  1. Has anyone got/used a machine from Black-Cat-CNC?
    By cjpwart in forum Milling Machines, Builds & Conversions
    Last Post: 12-08-2012, 05:15 AM
  2. The cutting fun begins
    By m.marino in forum Machine Discussion
    Last Post: 01-04-2012, 12:35 AM
  3. NEW MEMBER: And so it begins
    By compfranon in forum New Member Introductions
    Last Post: 27-03-2010, 11:58 AM
  4. BUILD LOG: The B&Q build adventure begins....
    By flez1966 in forum DIY Router Build Logs
    Last Post: 11-10-2009, 01:48 AM
  5. eBay: 2GB USB Flash Memory, Swivel Stick (black)
    By Lee Roberts in forum Items On eBay UK
    Last Post: 17-12-2008, 05:34 PM
