	29-10-2012 #1
I've come across a few interesting papers on machine design that other people might find a useful source of ideas for new builds:
Excellent and lengthy paper detailing a heavy duty design:
http://www.mech.utah.edu/~bamberg/re...e%20Design.pdf
Structural dampening to reduce vibrations:
http://mdrl.mne.psu.edu/papers/IntegratedApproach.pdf
equations to determine most effective means of layer damping with different geometries - Thanks Tenson.
http://www.dtic.mil/dtic/tr/fulltext/u2/a088200.pdf
Mechanical properties of wood composites (mdf/ply etc):
http://www.fpl.fs.fed.us/documnts/fp...chapter_12.pdf
Patent application: Improved damping of cast iron for machines:
HIGH RIGIDITY, HIGH DAMPING CAPACITY CAST IRON - Patent application
Optimum column design using honeycombs:
http://www.iaeng.org/publication/WCE...p1941-1947.pdfLast edited by D.C.; 02-11-2012 at 08:27 AM.
The Following 5 Users Say Thank You to D.C. For This Useful Post:
	30-10-2012 #2
	30-10-2012 #3
You might be interested in the second one aswell as you have a steel box section machine. The vibration damping seems to be massively improved by filling with pipes wrapped in damping tape and concrete compared to a plain concrete fill.
The Following User Says Thank You to D.C. For This Useful Post:
	30-10-2012 #4
moved to the FAQ's, Problems & Solutions and given a better title.
Nice post DC thanks !Lee
	30-10-2012 #5
Great info, though a lot of the first paper went over my head! :)
I'm pleased to see constrained layer damping is effective; I thought it might be a good way to go.
	30-10-2012 #6
Quick glance looks like there is some seriously heavy reading there so a lot will probably go straight over my head if I can't remember what I learnt all those years ago lol
Looks like a good find for those that will be able to understand it all though. I did learn enough to realise that I may need to rethink things, looks like my cardboard & selotape machine may have a few faults.
	31-10-2012 #7
Me too, I'm still being a bit of a dunce and can't find any material for muppets like me to bridge the math gap so I can understand how to apply the maths correctly myself but I can at least look at the pretty pictures. :)
I've just downloaded z88 so I can play with some FEA software, if I can outsource the clever bits to the computer I'm hoping I can get away with tweaking designs based on pretty colours...
	01-11-2012 #8
Another interesting paper here, showing equations to determine most effective means of layer damping with different geometries.
The Following User Says Thank You to Tenson For This Useful Post:
	02-11-2012 #9
Thanks Tenson, I added it to the original post so people won't have to read through pages of forum posts to get to the documents, is that ok?
	02-11-2012 #10
No problem, I just wish I could understand the paper better, lol!
Design Help Pt2 Required for CNC design/Build
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 38Last Post: 21-07-2014, 02:05 PM -
FOR SALE: Exel HD1013 heavy duty CNC router
By Deuce_Coupe in forum Items For SaleReplies: 0Last Post: 04-06-2014, 01:50 PM -
Interesting Mill Design on Hackaday
By epninety in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 01-03-2014, 05:10 PM -
Heavy Duty Extension Spring
By Stevetechguy in forum Manufacturer NewsReplies: 0Last Post: 17-10-2012, 04:45 PM -
