Thread: broken ultrasonic cleaner?
21-11-2012 #3
Last week my Kerry KC2 ultrasonic bath started to fail on me, so I have brought a new one to replace it.
My old one still works, but does not seem anywhere as powerfull as it once was.
I have not yet pin pointed what the problem is, so I don't know if the transducer is starting to fail, or a problem with the driver board.
With mine, I disconected the transducer, and powered up the unit, and using my DVM I would get a reading of around 600vac.
I used my picoscope 2202 to test the low voltage side of the signal gen for the drivers, and thats was switching at 40Khz, as expected.
As my picoscope does not support high voltage, I am unable to see what the wave form looks like to the transducer.
If you can open up your ultrasonic bath, and take some high rez pictures, we might be able to help you find what has failed.
Best Regards."If first you don't succeed, redefine success"
ultrasonic cleaners - cheapos good enough?
By dsc in forum Marketplace DiscussionReplies: 5Last Post: 23-07-2013, 11:54 PM -
uPVC CNC Corner Cleaner
By StuH in forum Machine DiscussionReplies: 2Last Post: 20-07-2013, 12:09 AM -
Newall DRO broken;-(
By graffian in forum General ElectronicsReplies: 2Last Post: 28-06-2013, 01:18 AM -
WANTED: Broken lathe??
By Jimmybristol in forum Items WantedReplies: 0Last Post: 10-01-2011, 07:27 PM -
Hey...I'm all (broken) lathed up!
By HankMcSpank in forum Lathes, Lathe Rebuilding & ConversionsReplies: 0Last Post: 27-07-2009, 02:02 PM
