Thread: PSU question
    24 volts max and 5 to 6 amps
    John S -
    Thanks John, is there a formula on how you reached that figure?
    Think you'll find the formula is 20yrs experience and several dozen blown Allegro(A4988) chips.?
    The Amp's is simple multiply the number of steppers Amp's plus a bit spare capacity.
    The lower voltage is safety margin due to the allegro chip being notoriously bad at letting out the Magic smoke any higher. Coupled with the fact the next standard PSU will be 36V.
    There is a wonderful gizmo called the "crowbar circuit". You put a fat Diac across the PSU output and a zenner diode to trigger it should the volts rise above your max threshold.
    When you trigger a Diac it stays triggered, hard on, until the Volts go away. A cheap Diac can handle lots of Amps.
    In this case the Volts go away because the fuse blows. You then replace a 10p fuse rather than expensive hardware.
    It's called a crowbar because the effect is like dropping a crowbar across the power input terminals
    in that case as i have four steppers i should look for a 7-8A ( 1.7x4 + a bit ) ideally?
  1. NEW MEMBER: Re my question
    By oldwoodworker in forum New Member Introductions
    Last Post: 20-09-2013, 09:07 PM
  2. To usb,or not to usb,that is the question.
    By Jumbo in forum General Discussion
    Last Post: 17-10-2011, 09:21 PM
  3. Just a small question
    By Wobblybootie in forum Linear & Rotary Motion
    Last Post: 06-08-2010, 05:28 PM
  4. question ...
    By Wobblybootie in forum General Discussion
    Last Post: 04-01-2010, 12:04 AM
  5. A question
    By bodgeitandscarper in forum Gantry/Router Machines & Building
    Last Post: 02-12-2009, 08:30 AM
