13-02-2013 #1
I have been doing some googlehopping to try and find something I need .. its here Pipe As it says in the advert Made of flexible,
"formable corrugated stainless steel, this product can flex and bend to make just about any shape, and will hold its shape once bent without leaking. It's easy to cut to length with a variety of tools including hacksaws, reciprocating saws, and cutoff wheels".
I want something like this about 3/4 to an inch bore to use for dust extraction I'm buggered if I can find a UK supplier or if there's another alternative that's used for something else ? Anyone any alternatives I only really need about a foot of it . I did try and make an extractor hood but I don't have the skills ( it fell to bits) so I'm just going to run the flexi pipe down to near the bit and suck up the dust like that. I have used compressor pipe and it worked ok but I cant get the angle i want under the spindle so the vacuum is not as affective. Can anyone help plz ?
Ralph Waldo Emerson
13-02-2013 #2
Try googling flexible exhaust pipe or
this on ebay
20mm ID 24mm OD 3/4" Flexi Pipe Tube 1metre Exhaust Flexible | eBay
Bill
13-02-2013 #3
I seem to remember that that type of tubing was called "Gooseneck" tubing... Hope googling that will help.
13-02-2013 #4
Ralph Waldo Emerson
13-02-2013 #5
It would actually be cheaper to buy a flexible lamp for £9.99 and strip of the gooseneck pipe !
Ralph Waldo Emerson
13-02-2013 #6
13-02-2013 #7
Ralph Waldo Emerson
13-02-2013 #8
go to your gas meter cupboard look at the pipe on the inlet of the meter that is connected to the regulator this is around 3/4 is stainless and is flexible if this is suitable and long enough for you i can get you one minus the regulator and all u would need to pay is whatever it costs to post
13-02-2013 #9
Hi have you thought of using flexible exhaust pipe just looked on the tinternet and found a company Spare Parts for Honda Belle Stihl Husqvarna | Chainsaw Spares | L&S Engineers selling 1.25 " dont know if its ss thou
13-02-2013 #10
Flexible exhaust pipe won't hold it's shape.
For cheap and easy, some 1" hose taped to a bit (or a couple bits) bent metal wire/bar.
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM -
RFQ: Require small Stainless steel buckles machining- can you help please ?
By Gasgasbones in forum Projects, Jobs & RequestsReplies: 0Last Post: 15-05-2013, 06:47 AM -
RFQ: RFQ: Micro Precision in Stainless Steel.
By mikewatch in forum Projects, Jobs & RequestsReplies: 3Last Post: 12-04-2013, 11:49 PM -
What kind of machine will do stainless steel or brass engraving
By JayPunchbuggy in forum Machine DiscussionReplies: 8Last Post: 13-03-2013, 10:40 PM -
stainless steel fasteners - quality
By dsc in forum Metalwork DiscussionReplies: 7Last Post: 30-11-2012, 12:35 PM
