17-04-2013 #7
Ok, firstly thanks to John for his offer to help - I had a moment of doubt late last night & have asked him to hold off while I mull the design over a bit longer.
There are a couple of things I need to address further down the line (not sure I should worry about them now).....
1. Repeatability - I can tell you with a degree of certainty, that aligning 0.15mm wire up at the zero poiint is a pain in the @rse...so I'd like to aim towards a way of automating that (some) form of homing the feed wire (optical perhaps?)
to take the visual guesswork out of this (unless you get the start point right...you end up with an uneven wind)
2. Speed of setting up (sort of related to No1) ....if my latest efforts work...I might need to make a lot - I don't want to get bogged down spending 10 minutes setting everything up!
....but I guess I can worry about those later ....pointless obsessing until I've proved the concept.
John mentioned in PM a couple of ideas re a better version.
A deluxe model would be like this guy has done....
he uses a linear actuator with a syringe attached to it (to feed the wire through) thread discussing here Working on a new winder. . . ...my needs are slightly different - guitar pickup makers are all winding very hair like thin wire with not so much tension, I'm winding 3x thicker wire under a fair bit of tension (I'd be worried about any syringe needle bending or scratching the enamel off the wire). While we are speaking of deluxe, there's also clanzer who's selling coil winders.... CNC Design Limited - CNC Coil Winder (but I prefer a solution where the main winding motor is a stepper vs a dc motor...I need a lot of torque at lower revs)
Juku...thanks for the link if I'm to go the way of a flexible coupling I think I'd go withe 6.35mm->7mm (which I can tap to M8 thread)
Ross ....I'm coming around to the idea of supporting the end of the threaded rod (perhaps not at the very end, but near the end with some bearings).... indeed here's a recent attempt (my machine isn't strong enough for ali, so I simply use acrylic)...
(just held together loosely to give you a vibe of what I'm thinking of...at least there's a bit more support near the end of the (M8) threaded rod)
for tension, I use the tried & tested two felt washers under tension to feed the wire through
Swarfing...anything that involves me, a drill & accuracy.... can only result in much hilarity & disdain from passing children!Last edited by HankMcSpank; 17-04-2013 at 09:23 AM.
A couple of general design questions - ball-screw thread length, stub-shaft etc.
By Wal in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 02-01-2015, 08:32 AM -
pulley fit on motor shaft - force it on?
By dsc in forum Belt Drive, Pulleys & TimingReplies: 2Last Post: 09-08-2013, 06:11 AM -
dc motor - spindle / shaft drive
By dsc in forum Spindles & Drive MotorsReplies: 21Last Post: 01-06-2013, 10:42 AM -
Threaded bar, steper motor and a plasma cutter.. your thoughts?
By gr8fun in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 27-11-2012, 05:14 PM -
Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
By LoveLearn in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 08-02-2012, 01:52 AM
