  1. The bottom 3 switches of the top bank are labelled 'motor curr'. Also 2 switches labelled 'resn' I'd guess are microstep setting?
    More intriguing are the 'setup' trimmers for accel, etc.
    Hi John
    We use this Parker equipment at work send me a pm with the model numbers I think we will have the manuals for them.
    Andy
    You can tell I hav'nt been on here for a long time!
    Nick send me your details including model numbers I,m sure I can help.
    Hi Irving
    These are used with DIP Switch 3 where you can have internal speed control.
    well cheers Andy, i'll post these pictures
Name:	2013-08-15 19.03.26.jpg
Name:	2013-08-15 19.03.36.jpg
    i also got this as it was attached to the 3 drivers, im not going to be using it,
Name:	2013-08-15 19.03.49.jpg
  5. Manual here http://www.parkermotion.com/manuals/PD/PDS_E.pdf‎
    2.5A min, 5A max driver in 350mA steps
    step settings 400, 1000, 2000, 4000 (i.e. 1/2, 1/5, 1/10, 1/20)
    opto-isolated inputs
    regenerative dump circuit
    is that good???? ive looked at the manual, but how easy is it to connect to a BOB board (if it can be run off a BOB board)
    Hi Nik
    The 6400 is a programmable motion controller we have some of the old 6200 which I have programmed, not really any good for CNC.
    You will have no problem running the drives from a breakout board.
    I have some of the same drives which I removed from decommissioned equipment at work, I haven't had time to play around with them yet.
    Is there anything in particular you want to know about the drives?
    Andy
    well as they had their own mains connection i did think i wouldnt need a big transformer or power supply to run my motors, thus an easier way to supply each motor, being a newbie i was hoping it was a simple act of connecting to the right break out board and they would all work in harmony, but as i didnt give anything for them its no loss,
    what actually comes out of a break out board to in turn make the motor driver do what it does
    Quote Originally Posted by DrNik View Post
    Just a 5 volt signal,the direction signal is either high or low which determines which way the motor turns and the step signal is a pulse (square wave).
    If I get time this weekend I will connect one of the drives I have to a motor and have play then let you know how I get on.
    Andy
    thanks andy thats great, but.........well it gets worse.......... popped in to see a mate today, id mentioed i was going to build a cnc plasma and should he come across anything keep it for me, well.............
Name:	2013-08-16 17.24.12.jpg
Name:	2013-08-16 15.39.40.jpg
Name:	2013-08-16 17.27.28.jpg
Name:	2013-08-16 17.27.56.jpg
    ive got 5 decent sized machines, was in excess of £125,000 each, all with 2 heads that machine 2 items at the same time, so ive got 10 lots of z axis setups,everything to run them as a stand alone system, even temperature controllers to keep them warm/cool, i'll list everything one ive managed to strip just the one, but take a look at the pics and see you guys think
  1. Cast aluminium gantry router
    By jrcast in forum Gantry/Router Machines & Building
    Last Post: 17-02-2017, 08:13 PM
  2. Semi - Experienced / Experienced CNC Turner required in Rutland
    By ChrisMunday in forum Opportunities Available & Sought
    Last Post: 05-02-2014, 11:08 AM
  3. Epoxy cast plastic injection tools
    By gavztheouch in forum Moulding Machines
    Last Post: 27-01-2014, 11:33 PM
  4. RFQ: Marking a cast iron
    By mike stat in forum Projects, Jobs & Requests
    Last Post: 13-09-2012, 10:22 PM
  5. Can anyone recommend a spindle for milling PCB and cast acrylic?
    Last Post: 11-10-2011, 08:54 PM
