Thread: Mach3 vs Mach4
birchy,
yes thats the right one. You can try the software in simulation mode but as far as I know you need his hardware to run it with a machine. I have been using it since I built my machine and I like it. It gets regular updates and Bert gets back to you quickly if you mail him with a problem or question.
17-08-2013 #2
18-08-2013 #3
Sour grapes to those that poo poo linux because they do not understand what they are doing without the crutch of microsft. Always used Emc2 (linuxcnc) and since setting it up never had a problem. At least the linux fraternity will never shove it's problem under the carpet. Once you get it set up it works great, the forum will get you through most problems you may have (not many as they have all been seen before). PC is biggest hurdle, but if you look on their site they list a good few that work but what i find is the simpler the machine and you switch all the on board stuff off that is not needed you are fine. Check out mother boards that boast high back bus speeds rather that processor speeds. a good chunk of ram, separate graphics cards with good ramdac and you are on your way.
18-08-2013 #4
Ah ah that's a joke surely.?? . . .Only last week on Mach yahoo someone was complaining that the almighty Linux guru's wouldn't or couldn't fix the G540 issue they insisted it wasn't Linux at fault it must be G540 or PC at fault.!! Even thou it works fine with Mach on same PC.!!
Now I know all software has bugs, Mach3 just like Linux has it's fare share but it's the manner of help that's available to the lay man that knows nothing about PC or Control software and in my experience thru helping and speaking to others and also listening to inexperienced and vastly experienced users alike who have tried both then Mach3 support is much better.
Also regards the software it's self they tend to like Mach better for it's flexibility and being very configurable to there needs with a much bigger user base of all experience levels.
Each to there own I suppose but my using Mach has nothing to do with Microsoft or any other operating system, I just like how it works and the fact I can contact the guy who writes the code that makes it run if needed.!! . . . Wouldn't care if it run on Wonker vision I'd still use it.!!
18-08-2013 #5
Ok answer me this because i don't know latest state of play.
In Mach if you break a tool you can pause, fit new tool, reset the offsets and carry on.
Now at one time in EMC as it was called you couldn't do this .
Les Newall of Sheetcam fame altered the program, changed it so it would and sent the code in.
To my knowledge and it's not current this still has not been implemented
Biggest problem with the development committee is they are programmers, not machinists and if they can't see a use for a feature it doesn't get put in.
Now someone will tell me yes like Les you can alter it but end of the day 99% of the uses just want to be button pushers.
The problem with geeks is they don't know they are geeks.John S -
18-08-2013 #6
John i can hit the stop button change tool and reset offset at any time throughout the cycle.
Like i said sour grapesAh ah that's a joke surely.?? . . .Only last week on Mach yahoo someone was complaining that the almighty Linux guru's wouldn't or couldn't fix the G540 issue they insisted it wasn't Linux at fault it must be G540 or PC at fault.!! Even thou it works fine with Mach on same PC.!!If the nagging gets really bad......Get a bigger shed:naughty:
18-08-2013 #7
I wouldn't call it sour grapes I'd call it far worse if I'd been using Linux before then upgraded all my control to run a G540 then Linux went "Computer says NO" ..!! But it worked fine on other control software on same PC.!
The comment was just to highlight BOTH software's have issues and the All might Linux GURU committee don't always fix issues and have the same "sweeping under" broom when it suits them.!!
Anyway I'm away to start making swarf soon can't hang around all day talking to you losser Geeks.!
