    Why don't you use steel profile gantry? Or at least steel profile and aluminum profile mix if you insist on using aluminum profile? Profile is much stronger than plate. It would be good idea to check your design with the calculator posted in the sticky area of the forum. Personaly i dislike plate sides of gantry if they are not double, imitating profile.
    I was thinking I might add a 12mm plate to the flat back side of the gantry to tie it all together. I know some designs have double gantry sides but I'm conscious of the gantry weight and also feel the depth of the gantry cross members will prevent any flexing of the sides. But I may be wrong !
    Thanks for your comments
    I assume your gantry will be 160mm high, that means for the 600mm travel you will use something like 1m of 160x12mm plate which weights 15kg. For example 1m 160x60x4mm steel profile weights 9 kg and would be stronger than your combined plate+aluminum profile.
  1. Replies: 12
    Last Post: 25-05-2013, 12:41 AM
  2. RFQ: Z axis and y axis carriage
    By D-man in forum Projects, Jobs & Requests
    Last Post: 08-04-2013, 10:06 AM
  3. NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
  4. Y axis is making X axis stall...!!
    By fasteddy in forum Machine Discussion
    Last Post: 24-10-2011, 12:19 PM
  5. Precision metal processing (3 axis, 5 axis, 7 axis) OEM
    By 7AxisCNC in forum Manufacturer News
    Last Post: 17-05-2011, 02:04 PM
