Those calcs are for steady state load and make assumptions about power factor etc. to limit core heating and losses. If you go that route you'll end up with a massively overspec'd, physically large and overpriced transformer.
Steppers are nothing like that, the duty cycle is nothing like steady state. I don't know why you have 6 motors but I'd be surprised if you need more than 60% of the total load and most of the peakiness is handled by the capacitors.
So use:
VAC = (VDC + 1.5)*0.7
IAC = IDC
VA = IAC * VAC, then chose next largest
for 2 parallel secondary windings each is rated at IAC/2
The 1.5 is voltage drop across rectifier, can be 1, 1.5 or 2 depending on product.
So 24A @ 60% = 15A approx. = IAC (or 2 windings @ 7.5A each)
VAC = (42+1.5)*0.7=30V
VA = 30*15=450 so use 500 or 625VA
29-10-2013 #2
Toroidal Transformer
By Carlb1058 in forum General ElectronicsReplies: 7Last Post: 17-08-2013, 06:54 AM -
Stepper Drives
By GTJim in forum Marketplace DiscussionReplies: 4Last Post: 05-04-2013, 12:05 PM -
Nema 34 Stepper Drives,
By drumsticksplinter in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 03-04-2013, 04:20 PM -
Toroidal transformer voltages - sanity check needed!
By m_c in forum General ElectronicsReplies: 16Last Post: 03-10-2011, 08:34 PM -
Contactor sizing?
By Swarfing in forum General ElectronicsReplies: 5Last Post: 27-12-2010, 08:58 PM
