Just about to make up some plates for my tool height setting. I am using a mill and remain nervous about the programme (2010) dropping my tooling onto a solid plate. Is it best practise to laminate either the fixed and/or movable plates to give some "sprung" resilience at touchoff?
12-11-2013 #2
Don't worry about it just keep the touch speed sensible and you won't have a problem. Think I have mine set to 300mm/min initial touch then 50mm/min for final touch.
Always best when first setup to place something soft under plate for testing. Ie sponge then after that always touch probe to earth and check light comes on before each use.!. . . . After that you won't have any trouble I use mine everyday with tool direct to aluminium with no plate used at all (Ie zero thickness for plate) just a wire touching material and doesn't even mark the material.
12-11-2013 #3
12-11-2013 #4
Probe Centering with Mach3 Tutorial
By Ricardoco in forum Probing, Digitizing & ScaningReplies: 9Last Post: 02-07-2016, 07:19 PM -
Help Please With Auto Tool Height Mach 3 Problem
By howser37 in forum Probing, Digitizing & ScaningReplies: 26Last Post: 12-06-2014, 07:55 PM -
another tool hight setting proble :)
By blackburn mark in forum Tool & Tooling TechnologyReplies: 4Last Post: 08-09-2012, 11:30 PM -
Problem with height setting in artcam express.
By don_jarr in forum ArtcamReplies: 4Last Post: 07-11-2011, 03:26 AM -
Setting Z height with an ER32 collet
By Robin Hewitt in forum Machine DiscussionReplies: 0Last Post: 27-03-2010, 09:16 PM
