  1. #31
    Quote Originally Posted by dsc View Post
    these DM856s all struggle with low frequency pulses / single pulse operation.
    Just use microstepping to increase the frequency. You'll loose incremental torque, but that most likely doesn't make any difference as you're only interested in the coarser steps.
  2. #32
    dsc's Avatar
    Lives in Lincoln, United Kingdom. Last Activity: 17-06-2020 Has been a member for 9-10 years. Has a total post count of 252. Received thanks 1 times, giving thanks to others 11 times.
    I think the issue here is that the motor doesn't want to remain in-between steps and falls back into the 'true' full step, which is why it doesn't move at all and jumps two micro-steps at a time. I need this to move a step / microstep and remain in that position for a long time, including down-time when not powered up, I simply cannot have it miss steps or jump steps.
    Regards,
    dsc.
  3. Then you can only use full steps. All forms of microstepping need power applied to hold position.
  4. #34
    dsc's Avatar
    Yes, I've just realised this. What's the normal work around if you need microstepping? 'Zeroing' on every power up?
    Regards,
    dsc.
  5. Well, re-homing certainly.
  6. #36
    Since you're already using a PIC, it would be easy enough to add an encoder to the motor and use it to keep track of the position.
  7. #37
    dsc's Avatar
    Well I could use an encoder, although I'd need an absolute one to know where the motor sits after power cycling the thing.
    Regards,
    dsc.
  8. #38
    dsc's Avatar
    Kudos again to Jonathan, I'm using 1/4 microstepping and sending four pulses to move a step. Works like a treat, no jumping, glitching, random movements.
    Regards,
    dsc.
  1. My turn for help with Pulse multiplier for test rig.
    By JAZZCNC in forum Electronic Project Building
    Last Post: 20-06-2014, 06:09 PM
  2. MPG or Hand Wheel Pulse Encoder where to buy in UK?
    By suesi34e in forum Marketplace Discussion
    Last Post: 02-01-2014, 04:41 PM
  3. Pulse rate or dip switch settings
    By Jopo in forum Stepper & Servo Motors
    Last Post: 29-04-2013, 08:08 AM
  4. Strange problem, possibly missing steps?
    By Philly in forum Chinese Machines
    Last Post: 26-10-2012, 06:36 PM
  5. Missing Steps + Stalling X-axis
    By danielbriggs in forum Linear & Rotary Motion
    Last Post: 02-09-2010, 02:59 PM
