Thanks for the quick reply Geoffrey.
Ok spindle it is, the router is out. My old router speed was 30000 the spindles that I was looking at has there speed range 3000 to 12000 for the 600 watt and 24000 for the VFD and spindle all my bits are single flute and V bits.
What do you mean about speed range
what speed range should I be looking for?
28-12-2013 #2
I just checked here Cutting Speeds - LittleMachineShop.com
and for a 6mm cutter is says about 2500 rpm for aluminium, I'm no expert on this though so just using the figures given. This implies you do need some speed control and 3000 may be a reasonable lower figure. Having looked at spindles, in some cases 24000 rpm is a special case in that it needs bearings to suite, 18000 rpm max. may be a cheaper route.
Also very important, the power of the spindle is usually quoted for max speed, so a 1.5kw 18000 rpm spindle would deliver 1.5kw at that speed only. At a lower speed it would be derated so would deliver considerably less. With this in mind and the fact you want to cut aluminium at low speed then a 1.5kw spindle would be the minimum I think.Last edited by EddyCurrent; 28-12-2013 at 04:40 PM.
28-12-2013 #3
The spindle power output is roughly proportional to the speed, so at just 3000rpm you only get a fraction of the rated 1.5kW. The question to ask therefore isn't, 'what is the minimum speed the spindle will run at?', it's 'at what point is the power output of the spindle too low to be useful?'.
If the list of materials you are cutting is complete, then the 1.5kW spindle will be fine. The only thing it would struggle at is if you need to drill the aluminium, but if you've got a pillar drill that's clearly not a problem.
With a 6mm carbide cutter you'd use around 13000rpm.
Yes and you wont even need the radiator if you have a good size tank of water/favorite solution.Last edited by Jonathan; 28-12-2013 at 04:39 PM.
Chinese 6040 CNC Router Advise Needed
By Bob Hepple in forum Chinese MachinesReplies: 24Last Post: 27-11-2013, 12:00 PM -
Has my air compressor died?
By Jonathan in forum General DiscussionReplies: 9Last Post: 15-10-2012, 12:08 AM -
I need advise again
By habibuzziwa in forum General DiscussionReplies: 14Last Post: 08-10-2012, 10:08 AM -
I need advise
By habibuzziwa in forum General DiscussionReplies: 7Last Post: 03-10-2012, 10:50 AM -
Advise on buying a new CNC router.
By brlaw in forum General DiscussionReplies: 2Last Post: 09-07-2011, 05:00 AM
