Thread: Milling mild steel
16-02-2014 #12
My first milling operations were carried out on a lathe with a milling cutter in the chuck and an angle plate and single axis slide mounted on the cross slide, it's fiddly and far from ideal but got a lot of small jobs done to the required spec with the only equipment I had.
I progressed to a spindle driven vertical milling attachment which allowed me to use the lathe cross slide as a table, it took quite a lot of work to adapt it to fit my lathe and rigidity wasn't great but it did some good work and was all I could afford at the time.
I'm sure a lot of the work these stop-gap measures allowed me to complete was "Impossible" in the eyes of a man with the ideal machine for the job, the correct machine for your job is the one which you have reasonable access to which can be made to complete the job to a standard you are happy with in a time you can put up with ;-)
- Nick
RFQ: Several mild steel parts
By dudz in forum Projects, Jobs & RequestsReplies: 6Last Post: 26-08-2013, 11:37 AM -
How do I get this widget made (a small rectangular bit of 1.6mm mild steel)
By HankMcSpank in forum Marketplace DiscussionReplies: 25Last Post: 03-05-2013, 09:31 AM -
Cutting 1.6mm mild steel with a CNC machine?
By HankMcSpank in forum Machine DiscussionReplies: 4Last Post: 01-05-2012, 09:56 PM -
Homemade desktop CNC - cutting 0.8mm mild steel out the question?
By HankMcSpank in forum General DiscussionReplies: 7Last Post: 16-04-2010, 09:37 AM -
Where to get 1/8" sheet mild steel laser/water jet cut?
By HankMcSpank in forum Marketplace DiscussionReplies: 28Last Post: 10-02-2010, 01:28 AM
