Thread: What's the best strategy ?
06-04-2014 #2
06-04-2014 #3
It looks okay but as usual the basic version just lacks the features required and when you start adding the modules you might as well have gone for the top version.
I think I'm going to have to run two lots of G-code, one from a 3D CAM such as DeskProto and one from a 2D Cam such as Vectric Cut2D.
As Gerry says if the origins match then all should be well.
Of course a 'pocket' is just a 'depression' for 3D CAM software but it won't generate the most effective or best toolpaths for that part of the project.Last edited by EddyCurrent; 06-04-2014 at 04:52 PM.
06-04-2014 #4
I've just had a look and it's got most of the basic features you need for both 2D and 3D so what is it you plan on doing that this £99 software can not do.? What you think you need may not actually be the case and you could be paying for features you'll never use.!!
That said.!! . . Regards the separate G-code then it's not difficult using cut and Paste to combine into one file. Just keep a Standard template file with your Header setup then cut and paste. I do this often when I'm setting up and using Fixture Offsets(G55, 56 etc) and want to combine individual parts saved in seperate G-code files into one file.Last edited by JAZZCNC; 06-04-2014 at 06:30 PM.
Minimal-cost Power Supply Strategy - Repurpose Laptop Power Supplies
By LoveLearn in forum General ElectronicsReplies: 0Last Post: 25-01-2012, 09:29 PM
