Thread: Spindle motor rewind
11-04-2014 #19
Thanks for the reply, but it is not possible to find a suitable replacement VFD. The problem as I understand it is that the spindle (900w max) is a 2 pole 3ph motor with a speed range of 15-60krevs at 15-60volts. I do not need that speed, so would be happy with 24krevs at 230volts and use an off the shelf inverter. I have been advised that whilst I may be able to set the voltage down that low with a 400hz inverter, these inverters are PWM and would still be applying a higher voltage for a short period to achieve the lower working voltage, but that the spindle low voltage windings will not be insulated sufficiently to cope with that. I hope that makes some sense. I certainly had the impression that the "impossible" comment was because there would not be enough space for the revised windings, or indeed that they were not really interested. The spindle body diameter is 62mm, but none of the rewinders I spoke to have seen the spindle, let alone examine it. G.
AC servo motor to replace a 3 phase induction motor on a mill spindle.
By rnr107 in forum Spindles & Drive MotorsReplies: 2Last Post: 23-04-2014, 03:14 PM -
WANTED: Router Spindle Motor
By swinds in forum Items WantedReplies: 3Last Post: 26-04-2012, 10:43 AM -
Spindle Motor
By pdl in forum Stepper & Servo MotorsReplies: 0Last Post: 09-08-2011, 10:56 AM -
Spindle motor problems
By geoffby in forum Motor Drivers & ControllersReplies: 11Last Post: 07-11-2010, 08:25 PM -
servo motor as spindle motor
By Scott in forum General DiscussionReplies: 1Last Post: 03-10-2010, 06:42 PM
