Thread: Ground loops and earthing
What happens then if using a zero touch plate for Z ?
03-07-2014 #2
03-07-2014 #3
Just asking on behalf of andy586 as he may come across this requirement later and I didn't want to steal your thunder by replying myself.
03-07-2014 #4
No your being a smart Arse Eddy but just for the sake of others and Andy586 I'll answer it.
To be 100% sure touch probe will work then you should use Input (+) & (-) terminals with Clip to spindle and Plate for touch off. Yes Spindle may be connected to Earth thru the BOB but you don't know that for sure and actually better quality BOB's or Motion control cards with direct I/O (Like CSLAB's products) don't actually allow this to protect there inputs and protect against Noise etc so force you to use dedicated Negative so they know every thing is at the same potential.
Just because it works doesn't mean it's correct way or actually safe for the BOB.!
03-07-2014 #5
03-07-2014 #6
11-08-2014 #7
Many thanks for the replies. Got it all sorted now. Much appreciated!
Earthing?
By manofgresley in forum General ElectronicsReplies: 70Last Post: 29-03-2018, 11:56 PM -
Laser Machine Grounding/Earthing
By Want2build1 in forum Laser Machines & BuildingReplies: 31Last Post: 09-02-2015, 10:18 PM -
threading ground bar ends
By dazza in forum Metalwork DiscussionReplies: 39Last Post: 11-02-2014, 11:41 PM -
FOR SALE: Strong steel welded base with ground flat surface.
By black5f in forum Items For SaleReplies: 0Last Post: 14-01-2012, 07:20 PM -
RFQ: Precision Turned/Ground parts
By Jimmybristol in forum Projects, Jobs & RequestsReplies: 0Last Post: 08-01-2011, 04:12 PM
