    I have been trying a 6mm single flute carbide bit @ 21000 RPM 400mm Feed and 2mm depth, but the subject always gets to hot see pic:-
    should i try faster feeds? slower spindle ? deeper cut ? or some form of coolant / lube ? to resolve the heat build up.
    Id say its too fast(rpm)try knocking the spindle speed down by 1000 rpm increments jogging back and fourth on a bit of scrap acrylic.
    Quote Originally Posted by deisel View Post
    Agreed - the chipload is too low so you need to decrease the spindle speed and/or increase the feedrate.
    Acrylic as a very narrow chip load range and thats why it melts so easliy. I'd be going for higher feed rate first as 400mm/min is way to slow. Try 18000rpm and 900-1200mm/min then play around with both. Thou i'd be going higher on feed not slower. You'll definatly be wanting to at least double your original 400mm/min. I'd also cut with more DOC start with 50% cutter Diameter but it's not unusual to cut at 100% cutter dia.
    The type of acrylic also plays a big part to how it cuts.! Extruded can be a pig to cut and Cast tends to be better.
    I'd go down to about 12,000 rpm and 2000mm/min. I've used similar numbers on acrylic in the past.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    Last Cast acrylic I cut was 10mm thick and I cut it single pass with 8mm spiral upcut cutter at 24000rpm and 1200mm/min and it left a lovely finish but I thought these figures might scare him. . Lol . . . . Funny stuff acrylic and I find the larger the cutter the better finish I get.!!
    lower spindle speed seemed alot better here are some test results @ 9K 700-800 x 2mm ( im increasing slowly :) )
    Thanks for the tips
    Quote Originally Posted by Dwayne Dibbley View Post
    Thanks for the tips
    Try increasing the DOC and see if that helps often does. Have the tool under engaged is one the most common reasons for poor finish and excess tool wear.
  9. Jazz is correct on increasing DOC. Also as Jazz posted you really want to work with Cast not extruded. Cutting a lot of acrylic for sign folks and the best I can suggest has for the most part been stated. The only thing I can add is that you want to stay with either two flute or single flute for the best finish. Also doing a finishing pass in the opposite direction will aid greatly in the quality of finish you get (this does include areas where you have not cut all the way through). The only exception to the second pass I have found is when cutting with a V carve bit, than it is one pass and the job is done. -Michael
    Software SolidWorks 2024, Onshape, Aspire v9.5, Blender
    CNC Machine: http://www.mycncuk.com/threads/3661-...Second-machine
    3D printers both FDM/FFD and MSLA resin
    CSWA &CSWA-AM certified
    www.marino-customs.com
    Can you easily tell if the acrylic is cast or extruded by looking at it? ( no it does not have a label on it :) )
  1. Acrylic Cutting Help
    By Tenson in forum Machine Discussion
    Last Post: 08-11-2016, 08:15 PM
  2. Acrylic or mdf I can cnc
    By rainboweyes in forum Opportunities Available & Sought
    Last Post: 19-02-2013, 02:09 AM
  3. Drilling Acrylic with CamBam
    By m.marino in forum Machine Discussion
    Last Post: 06-06-2012, 04:45 PM
  4. Which end mill to level my acrylic bed?
    By HankMcSpank in forum Tool & Tooling Technology
    Last Post: 03-02-2012, 02:57 PM
  5. Acrylic suppliers
    By Web Goblin in forum General Discussion
    Last Post: 24-10-2011, 09:11 PM
