    lower spindle speed seemed alot better here are some test results @ 9K 700-800 x 2mm ( im increasing slowly :) )
    Thanks for the tips
    Quote Originally Posted by Dwayne Dibbley View Post
    Thanks for the tips
    Try increasing the DOC and see if that helps often does. Have the tool under engaged is one the most common reasons for poor finish and excess tool wear.
  3. Jazz is correct on increasing DOC. Also as Jazz posted you really want to work with Cast not extruded. Cutting a lot of acrylic for sign folks and the best I can suggest has for the most part been stated. The only thing I can add is that you want to stay with either two flute or single flute for the best finish. Also doing a finishing pass in the opposite direction will aid greatly in the quality of finish you get (this does include areas where you have not cut all the way through). The only exception to the second pass I have found is when cutting with a V carve bit, than it is one pass and the job is done. -Michael
    Software SolidWorks 2024, Onshape, Aspire v9.5, Blender
    CNC Machine: http://www.mycncuk.com/threads/3661-...Second-machine
    3D printers both FDM/FFD and MSLA resin
    CSWA &CSWA-AM certified
    www.marino-customs.com
    Can you easily tell if the acrylic is cast or extruded by looking at it? ( no it does not have a label on it :) )
    With a bit of Internet searching……
    How to tell whether its extruded or cast:
    "Burn a piece , extruded burns silently and will drip molten balls , cast burns with a crackly/smokey flame and wont drip. "
    "Another point worth mentioning is that extruded stinks when it's cut but cast has an almost sweet smell."
    And on this forum, from John S in Feb 2013
    "Extruded has white backing on one side and clear on the other.
    Cast has clear backing on one side and white on the other."
    Personally, I would only trust John.
    Both are true but I'd say the sound is more a Sizzling that crackling sound. The smell is definately sweet smelling.
    You do realise John's favorite pass time was taking the Piss.!!
    Who'd a thunk it. - Yes, I realise what the man is about, but I respect his opinion as an engineer.
  8. Quote Originally Posted by Dwayne Dibbley View Post
    Normally Cast has a white film on it and extruded has a clear film on it. Notice I say normally, I have seen otherwise on more than one occasion. That and ask for cast only when you buy it. Be careful though as some will say it is cast over the phone and you will get extruded. -Michael
    OK I have burnt a piece last night, it was silent burning so could be extruded it also has a clear cover on it so would also point it as extruded.
    I have ordered some 12mm cast to see if i get a different result.
  10. Looking at some cut pieces of both here in the shop I noticed that clear cast has no colour to it and extruded has a bluish tint to it as indirect light hits them. Don't know if this is always the case but just noticed it while looking over shoulder at the cut pile of pieces for machining. Michael
  1. Acrylic Cutting Help
    By Tenson in forum Machine Discussion
    Last Post: 08-11-2016, 08:15 PM
  2. Acrylic or mdf I can cnc
    By rainboweyes in forum Opportunities Available & Sought
    Last Post: 19-02-2013, 02:09 AM
  3. Drilling Acrylic with CamBam
    By m.marino in forum Machine Discussion
    Last Post: 06-06-2012, 04:45 PM
  4. Which end mill to level my acrylic bed?
    By HankMcSpank in forum Tool & Tooling Technology
    Last Post: 03-02-2012, 02:57 PM
  5. Acrylic suppliers
    By Web Goblin in forum General Discussion
    Last Post: 24-10-2011, 09:11 PM
