Page 3 of 7 FirstFirst 12345 ... LastLast
  1. #21
    Lives in Marple Stockport, United Kingdom. Last Activity: 19 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Ok Mike Unless you change the dip switch setting (on the driver) for the micro steps you don't need to touch that.
    That setting is to set up the machine so that when you tell the machine move say 50mm it actually moves 50mm.
    I would now move the steps to 1/4 which would be 160 by setting K1 and K2 (look the switch position up in the manual) on the driver and then change the Mach3 steps from 320 to 160. (re read EddyCurrent post #5).
    See how it runs then. Just change one thing at a time. When you say grinding noise, are you running the motors on or off the machine? ..Clive
  2. #22
    Hi Guys
    I have been watching this thread and can offer no advise regarding the electronics/drive side, but would it not be prudent to disconnect the the ball screws and check to see if the axis are moving freely.
    Just a thought.
    Mike
  3. #23
    I would have said set it to 4 myself but looking at the photo the options seemed to be 1,2,8,16 unless I've read that incorrectly.
    Hi Guys
    Just a thought.
    Mike
    In the video the motor was removed from the machine and just lying on the bench
  4. #24
    I don't have a manual for this board. And I can't find one on line. So I'm not sure where. To set the switches. I'm guessing that k1 and k2 can be on or off. And at the moment they are both set to on? So I need to change this.
    if I was to replace this board what would you go for?
  5. #25
    All axis run free with the strippers removed with strippers removed
  6. #26
    I could maybe use the stepper drivers I have and get a new PP based BOB. Or maybe replace the all in one board with a new all in one board. But what would you go for in each scenario
  7. #27
  8. #28
    Quote Originally Posted by amxen View Post
    Mike Is this the board http://www.aliexpress.com/store/prod...572788008.html what info do you have regarding the settings for the switches K1 and K2 As Eddy says you might have to try half step but we need the settings for the switches first.
    You can of course use your other drives but Keep trying this one first. I am having to earn a crust this afternoon but will get back later The supplier must have given you some sort of instruction to set micro settings. ..Clive
  9. #29
    Clive, picture 2 here shows the settings.
    http://www.mycncuk.com/threads/7871-...1513#post61513
    I see from your link Clive that K3 and K4 refer to 'buffering', I was thinking it meant standstill current due to the percentage symbol
  10. #30
    I'm pretty sure I got nothing regarding the micro settings. I got one sheet of paper showing how to put the parts together that was unreadable.
  1. New 6040 owner looking for advice from others with a chinese 6040/3040
    By itsmillertime in forum Machine Discussion
    Last Post: 14-10-2019, 08:30 AM
  2. Chineese 6040 problems
    By Kendrick57 in forum Gantry/Router Machines & Building
    Last Post: 18-10-2015, 10:52 PM
  3. Chinese 6040 from uk eBay seller x axis problem
    By CommanderKenyon in forum Gantry/Router Machines & Building
    Last Post: 20-02-2015, 02:13 AM
  4. my 6040 experience (yeah, and problems) so far
    By jimbo_cnc in forum Machine Discussion
    Last Post: 07-10-2014, 11:26 AM
  5. Chinese 6040 CNC Router Advise Needed
    By Bob Hepple in forum Chinese Machines
    Last Post: 27-11-2013, 12:00 PM
