Thread: What Toroidal parts do i need
there are no big price differences between toroid and switched-mode power supplies anymore.
I'd always use a switched-mode power supply for CNC machines because they offer some advantages:
- You get a finished, reliable product - no need to choose components and solder them together.
- It won't blow your fuses from time to time like many large toroids do if you don't use a current limiter.
- Most Important: Load and idle voltage is constant. With a toroid you have to take care to keep idle voltage below the drivers maximum voltage rating - but once the machine starts running this voltage will drop and you won't get the maximum speed and dynamics you'd get if you use a switched-mode power supply.
Christian2D / 3D CAM Software and CNC controller: http://www.estlcam.com
26-09-2014 #2
silly question but dose it matter what bob you use. Seems to be loads about but dose it matter what you use
26-09-2014 #3
This is taken from the Leadshine drive manual:
Regulated or Unregulated Power Supply
Both regulated and unregulated power supplies can be used to supply the drive. However, unregulated power supplies are preferred due to their ability to withstand current surge. If regulated power supplies (such as most switching supplies.) are indeed used, it is important to have large current output rating to avoid problems like current clamp, for example using 4A supply for 3A motor-drive operation. On the other hand, if unregulated supply is used, one may use a power supply of lower current rating than that of motor (typically 50%
~70% of motor current). The reason is that the drive draws current from the power supply capacitor of the unregulated supply only during the ON duration of the PWM cycle, but not during the OFF duration. Therefore, the average current withdrawn from power supply is considerably less than motor current. For example, two 3A motors can be well supplied by one power supply of 4A rating.
It is generaly accepted that unregulated power supplies handle back emf better than regulated.
Hi Clive the links don't work any more they changed the site. Also I don't need 50v that's a bit much for my drivers.
26-09-2014 #4
regulated power supply usually refers to linear regulators with typically small output capacitors.
Industrial switch mode supplies on the other side have quite large output capacitors or inductors and are perfectly suitable for stepper drives.
27-09-2014 #5
Industrial thats the key word here.!! . . . . . The problem with Unregulated switch mode supply with correct voltage and amp's is the cost. Industrial supplies that you can trust are very expensive and the Cheap chinese ones blow up for fun and are a lottery what you actually get out of them dispite what the ratings say.!
So Compared to Torodial built supply which you can taylor exactly to your needs regards V & A Good Switch modes are very expensive. Every machine I build use's custom built toroidal supply and I don't get any issues with blowing fuses. Only one time did I have any problem with a sensitive fuse tripping and changing the B rated fuse for a C rated eliminated the issue. Plus if this happens it's mostly on larger Va transformers not small ones.
Amxen Man:
You need 30Vac 2 x 15 transformer like this. Wire it in series as it's easier and neater IMO. If your not sure what we mean by series or parallel just ask it's simple.
http://www.airlinktransformers.com/c...nge/CM0300215/
3 x 4700 Caps rated 63V this will be the most common to find. Wire them in parallel so + to + to + to fuse rail and same for negative side. What you pay will depend on if you don't mind soldering or not. Clamp ones are expensive. See here.
http://uk.rs-online.com/web/c/passiv...984,4294466590
Then Simple 25A Bridge Rectifier. Something like this will do it's OTT but better that way.
Mount it on a piece of aluminium or heat sink. I find best thing to do is to mount the whole lot on piece of 3mm aluminium plate which then acts as a heat sink for the Bridge Rec.
http://uk.rs-online.com/web/p/bridge...fiers/8023240/
Regards Resistors to drain cap's then I use the NC contact of the relay which I use for E-stop circuit which then pulls in a Resistor to drain the Caps quickly.
That said you can get away without one if you like because the drives tend to drain the caps for you. Best to make use of the enable signal thou if your using this technique to avoid any chance of motors running on slightly while drives drain.
Other thing to be aware of with these supplies is that what you get out depends what you put in.? So if your mains supply is on the lower or higher side then you might not get exactly 42Vdc could be slightly lower or higher but you have enough safety margin so it's not an issue but don't be surprised or think you have done anything wrong if don't get exactly 42vdc.! (Little more wouldn't hurt anyway, your well safe @ 42v).Last edited by JAZZCNC; 27-09-2014 at 11:49 AM.
27-09-2014 #6
Thanks jazz i now have them all book marked. i have noticed you have visited this subject many times over the years and i respect your views on newbies and electronics. I still cant find a good newbie how to on this subject eg a step by step how to for people that can use a soldering iron and a mulitmeter but have no real electronics knowledge. I mean i can strip a combi boiler into it component parts and test each part to determine if its working or not. I can test resistance on a thirmister at a given temp , test continuity on a gas valve . but im not clued up enuf to go at this with out a thought for safety ,even thow its more than likely going to be easy. Is there a good how to on the net. iv been looking all day ?
help sizing toroidal PSU to stepper/drives
By paulus.v in forum General ElectronicsReplies: 13Last Post: 28-01-2014, 06:40 PM -
NEW MEMBER: CNC Router Parts
By CRP in forum New Member IntroductionsReplies: 4Last Post: 29-10-2013, 02:37 AM -
Toroidal Transformer
By Carlb1058 in forum General ElectronicsReplies: 7Last Post: 17-08-2013, 06:54 AM -
RFQ: Some parts.
By jcb121 in forum Projects, Jobs & RequestsReplies: 8Last Post: 22-03-2012, 05:07 PM -
Toroidal transformer voltages - sanity check needed!
By m_c in forum General ElectronicsReplies: 16Last Post: 03-10-2011, 08:34 PM
