I watched a TV prgramme this week called "Wheeler Dealers", they bought a car from the US, a 1969 Carmen Ghia. There was not one bit of rust on it, and as the presenter said, in the UK there is no way that could happen due to the weather. I think it's the same with these wooden machines, most I see are in the US and not subject to UK atmospheric changes.
I found steel and aluminium to be no harder to work with that wood, in fact steel is easier because mistakes are easy to repair with a welding rod. Aluminium is like using hardwood, I used woodworking tools for all my milling and cutting operations on it.Last edited by EddyCurrent; 15-11-2014 at 11:34 AM.
15-11-2014 #2
Building it using epoxy will completely seal against moisture.
The mentioned situation on wheeler dealers also has something to do with the way cars were painted back then...
The same goes for Wood and epoxy, when used together from the start.
(I have a wood-epoxy boat, with wood-epoxy fuel- and water tanks and very much used to working with the stuff.)Last edited by Sven; 15-11-2014 at 12:06 PM.
15-11-2014 #3
I'm loving these ideas. I use to look after our water ski racing boat years ago so I can work with epoxy I've even seen boats made from balsa wood, epoxy and glass fibre. I could be tempted to do an interesting build from unusual materials another day. Keep these ideas coming my imaginations going wild here.
Eddy' did you find any drawbacks in rigidity across the y axis with your open ended design? I was thinking it had to be a box type design but you have 100x50 box section on the X axis and nothing at the ends on the Y axis. I like this idea!
15-11-2014 #4I think it's the same with these wooden machines, most I see are in the US and not subject to UK atmospheric changes.
I'm currently working on a 4x8 dual spindle wooden machine. It's very complex, with lot's of laminated materials, bonded in phenolic for rail mounting surfaces (cnc machined straight and flat), and lots of aluminum for mounting surfaces (motors and drivetrain components) and brackets. And lots of epoxy.
It's a lot more work then building with steel, but I find it easier and far more enjoyable than working with steel. But it definitely takes a lot longer, and requires a lot more thought when designing.
You can easily weld two pieces of steel together at a 90° angle, and get a very strong joint. Try to do the same with wood, and it's much more difficult, and will almost always be a weaker joint.Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
15-11-2014 #5
Wow slow down lady's no one actually said it wasn't possible to build a good router from wood.!!
I personally said wood and inparticular MDF is not a good material for a CNC machine which it isn't.. . Period.!. . . . . HASS build routers and Mills but they don't make them from MDF or Wood do they.!! . . . I never said it wasn't possible and having worked with wood all my life I know it's possible but I also know it's far from ideal and much much more work than steel.
Also carry's with it a much higher potential for failure and dissapointment even for someone compleltely used to working with wood and tooled up.
Ger is correct that most Wood based routers fail because of poor engineering or design. Often they are also compromised by the type or quality of components used and most that take the Wood route do so for budget reasons so use inferior components which just greatly compounds the issue.!
I've seen many 1000's of good builds from steel/aluminium but I've seen relatively few Good successful Wood builds.!! . . . . . For sure This doesn't mean they are not being built from wood just that they rarely last very long or are successful so don't get seen.!
BUILD LOG: My Budget CNC Router
By Nealieboyee in forum DIY Router Build LogsReplies: 8Last Post: 14-11-2012, 12:57 PM -
CONVERSION: X2 conversion on a budget!
By craigrobbo in forum Conversion Build LogsReplies: 1Last Post: 30-10-2012, 05:00 PM -
Hardwood Supliers?
By Stickio in forum Marketplace DiscussionReplies: 3Last Post: 06-01-2011, 11:21 AM -
Which spindle with a £200 budget?
By fasteddy in forum Marketplace DiscussionReplies: 11Last Post: 29-06-2010, 11:51 AM -
Some thoughts on budget workshops
By irving2008 in forum General DiscussionReplies: 1Last Post: 02-08-2009, 04:11 PM
