The stepper is straight into the pinion with no reduction box ? Is that right ?
08-12-2014 #2
Yes there is is no reduction, im starting to think this is probably the problem, it seemed ok on my old machine though, but i guess the extra mass combined with hitting a hard bit of plywood could be enough. It occured to me thT the x axis is cutting accross the grain, and the y is cutting down the grain, which might explain why the y axis seems ok.
James
09-12-2014 #3
I think you are running the spindle too slow, 16500 to 18000 sounds better, also the depth of cut seems high, and your feedrate is too high.
So I would try this to see how it cuts; speed 18000rpm, depth of cut (with 4mm dia.tool) 2mm, feedrate 800mm/min.
If that works okay you can try to increase the depth of cut and feedrate until it starts to fail.
Plywood has grain going at 90 degrees to each other in adjacent layers so there is no 'with' or 'across' the grain.Last edited by EddyCurrent; 09-12-2014 at 12:25 AM.
09-12-2014 #4
Cheers Eddy, i will try that tomorrow, i used to run at similar feed rates (2-3m/min) with my old machine, when i decreased feedrate it started overheating cutters due to decreasing the chip load, as i had to run the router at full speed to get full torque, so ill start with the numbers you suggested and check the cutter for over heating, im just a bit wary of running too slow feedrate/ too high spindle speed.
TBH i thought i was taking it gently, i used to take 6mm deep passes with a 6mm cutter with a wood router, and this spindle is more powerful... But ill try it shallower. Ive not used 4mm cutters before and yeah 12000 is a bit slow if there smaller then the cutting edge is not moving as fast as a 6mm cutter would, add that to me running too slow and i recon that could cause the problem.
Yeah your right, i do know this i work with birch ply a lot, just my brains a bit scrambled today...it does cut more cleanly on the surface when you cut down the grain though.
Thanks again
James
09-12-2014 #5
09-12-2014 #6
I ran it today and cut a few more parts at 18000rpm, 1500mm/m feed rate and 2mm deep passes and it didnt miss any steps, ill finish it off tomorrow at 3mm deep and see how it does. It might just be that the plywood is really hard due to the cold, its not been much above 0 degress in my workshop for about a week now.
09-12-2014 #7
Sounds good, maybe you should invest in a wood burner, this is the one I use and it's great; http://tecnikstoves.co.uk/8-kilowatt-stoves
10-12-2014 #8
Give us some more info on system like motor wiring parallel or serial, voltage, micro stepping etc drives are running at to get better idea of system.
But still your going to want a ratio applying as 20t pulley direct drive means 63mm pitch which is way too high really and torque low so any stiction will have an affect which is why your bogging down. (2m/min shouldn't be a problem in plywood)
If you use 3:1 ratio you'll triple the torque and put the motors in an rpm range there more happy running and still get decent rapid speeds, well in excess of 10M/min.
So, what am I missing?
By Davek0974 in forum 3D Printing MachinesReplies: 4Last Post: 25-02-2014, 12:52 PM -
clunks / missing steps - DM856 and single pulse operation
By dsc in forum Motor Drivers & ControllersReplies: 37Last Post: 09-12-2013, 02:22 PM -
Strange problem, possibly missing steps?
By Philly in forum Chinese MachinesReplies: 5Last Post: 26-10-2012, 06:36 PM -
Boxford TCL 125 missing software
By Boxster in forum Boxford LathesReplies: 13Last Post: 03-07-2012, 06:21 PM -
Missing Steps + Stalling X-axis
By danielbriggs in forum Linear & Rotary MotionReplies: 5Last Post: 02-09-2010, 02:59 PM
