Thread: taper bearing.
The races are probably notchy because they have been left stationary with a heavy preload.
The lathe will only be as good as the bearings so it is worth getting good quality ones. I wouldn't think £10 car wheel bearings are not going to give a good result. You can use lower spec bearings but you need decent test gear to find and balance out the high and low spots. You may get lucky but I have only seen cheap bearings used when the the nose register and internal taper have been cut in situ once the bearings have been fitted.
Spindle bearings have the high spots marked and come in matched pairs so minor errors cancel out.
11-12-2014 #2
taper roller bearings vs deep groove ball bearings
By dsc in forum Linear & Rotary MotionReplies: 8Last Post: 10-03-2014, 08:06 AM -
Morse taper drills
By John S in forum Marketplace DiscussionReplies: 7Last Post: 08-05-2013, 07:00 PM -
Why do I get a taper when turning?
By irving2008 in forum Lathes, Lathe Rebuilding & ConversionsReplies: 15Last Post: 16-12-2012, 10:48 PM -
larger home made milling spindles - NMTB/ R8 taper?
By jonnydeen in forum Tool & Tooling TechnologyReplies: 6Last Post: 13-09-2012, 11:17 AM -
FOR SALE: Clarkson Autolock Collet chuck set, Boxed INT 30 / NMTB30 taper
By swarf-boy in forum Items For SaleReplies: 0Last Post: 04-01-2011, 05:28 PM
