Thread: Q: 24V Line driver IC
27-12-2014 #8
If you are going for differential pairs, then I wouldn't worry too much about what voltage the differential pair is running at. 5V is prefectly good for differential systems, as that's voltage what most modern CNC encoders operate at.
The key feature of differential pairs, is any noise that gets picked up, should be cancelled out by it affecting both wires by a similar amount and the differential voltage remaining reasonably constant. (This is a very basic explanation, which I'm sure Jonathon will criticise me for it!)
If you're running single ended, then yes, a higher voltage is better, which is why industrial machines nearly always run 24V control systems.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
cutting a fine line
By cubikoman in forum Tool & Tooling TechnologyReplies: 6Last Post: 19-02-2017, 10:04 AM -
Does anyone know about CAD/CAM courses on-line?
By hoezap in forum Marketplace DiscussionReplies: 7Last Post: 04-12-2012, 12:26 PM -
Line fonts
By daveshorts in forum Computer SoftwareReplies: 4Last Post: 07-09-2010, 04:43 PM -
CamSoft is on-line
By CamSoft Corp in forum CAD & CAM SoftwareReplies: 1Last Post: 13-01-2009, 12:55 AM -
Mach3 / Laptop No line driver !
By bruce_miranda in forum Artsoft Mach (3 & 4)Replies: 1Last Post: 11-09-2008, 05:42 PM
