  1. #19
    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 06-06-2026 Has a total post count of 295. Received thanks 2 times, giving thanks to others 79 times.
    What do you have in mind to use it for? Sure you have some plan.
    I use my CNC for small motorcycle parts. The 3D printer add on, is just because I would like to learn it, and to let my children learn something new.
    I have always thought of 3D printers as Useless , apart from making parts for other 3D printers. But the wife though it was a good idea, so I thought I'd have a go. So far all I have seen is toys and 3D printer parts made. I am sure I will come up with something one day .
    If this gear will extrude Nylon or Delrin ( Acetal ) plastics, then I can think of a few good uses straight away.
    Thanks for steering me towards the better quality stuff. I hate the "half a job" route.
    Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
  1. Advice needed on Amadeal
    By croy in forum General Discussion
    Last Post: 21-08-2015, 01:28 PM
  2. What's needed for a 3d printer build??
    By Davek0974 in forum 3D Printing Machines
    Last Post: 18-02-2014, 11:54 AM
  3. Quick Advice Needed - F&S
    By Tenson in forum Tool & Tooling Technology
    Last Post: 01-01-2013, 06:38 PM
  4. RFQ: Looking for member with water cutting ability
    By m.marino in forum Projects, Jobs & Requests
    Last Post: 06-07-2011, 03:30 PM
  5. SPG X3 CNC Mill, advice needed please
    By shaggyhawkings in forum Milling Machines, Builds & Conversions
    Last Post: 07-01-2010, 11:00 PM
