    It does have an emergency stop button
    is it as simple as just removing one wire from the emergency stop button and wiring the limit switches ad a daisy chain ( in series) from that wire back to the board?
    Quote Originally Posted by Janste View Post
    Yes it is that easy if you want it to be. Like Eddy says you'll need some way to get off the switches so you'll need an override momentary switch you can hold down to by-pass the limits while you ride off the switch.
    On the other hand if you use a separate switch for limits you can use mach's auto limit override feature which allows you to reset and back off the switch without a override switch. This can't be done if you wire in series with E-stop as the E-stop input will never reset so won't allow a reset.
    Thanks for the reply's
    I am following most of it lol
    I am running Mach3
    I like the sound of the separate switch for limits so I can use Mach's auto limit override
    I have watched the Mach3 limit setting video a few times and it seems ok to follow
    what I cant fathom is how/where to put the separate switch and how to wire up at the box
    thanks again guys
  1. Wiring home and limit switches
    Last Post: 18-11-2023, 06:14 PM
  2. EMC2 home/limit switches... only acting as limit?
    By vputz in forum LinuxCNC (EMC)
    Last Post: 15-10-2014, 09:51 AM
  3. Limit Switches
    By Leadhead in forum General Electronics
    Last Post: 16-10-2013, 10:41 AM
  4. Limit Switches with LED's
    Last Post: 02-01-2013, 03:08 PM
  5. Limit Switches
    Last Post: 27-06-2008, 02:21 AM
