    Hi Jazz, thank for your welcome
    Ive got a standard PC up in the loft, I'll dig it out and get Mach 3 on it, or is there something better I can use?.
    Quote Originally Posted by DrNik View Post
    Ye but be damned If I'll tell ya if your who I think you are.!
    I've got some ideas on my table, have bought some stepper motors, 23 for y and z and 34 for x, I'm looking at timing belt on the x and only running one motor,pic below
    2 pieces of timing belt tensioned on either side of the table, goes round a couple of bearings to keep the belt tight around pulley and then upto the top belt, maybe small timing pulley on motor to gear down the ratio, then passing the timing belt over to the other side, down the shaft and similar belt assemble onto other side, should be easy to time up and keeps it tidy
ID:	14894   Click image for larger version.
  1. Building my own 3D printer
    By Washout in forum 3D Printing Machines
    Last Post: 22-08-2014, 03:15 PM
  2. Help on building an enclosure
    By thomashomer1986 in forum General Electronics
    Last Post: 02-02-2014, 06:38 PM
  3. NEW MEMBER: Hi from Gloucester
    By richie00boy in forum New Member Introductions
    Last Post: 27-08-2012, 05:29 PM
  4. NEW MEMBER: Hello from Gloucester
    By Damian in forum New Member Introductions
    Last Post: 12-01-2011, 02:10 AM
  5. NEW MEMBER: Started building!
    By bobgrant in forum New Member Introductions
    Last Post: 02-09-2010, 09:42 AM
