Page 3 of 3 FirstFirst 123
  1. #21
    Brass bar stock is cheap enough, I suspect you could knock out a few dozen in an hour once you have the tooling and a procedure set for your lathe.
    The topic title does lead one to think down a riveting specific mechanical route ;-)
  2. #22
    mekanik's Avatar
    Lives in Barrow in Furness, United Kingdom. Last Activity: 15 Hours Ago Has a total post count of 807. Received thanks 101 times, giving thanks to others 176 times.
    You are correct the OP was looking for an off the shelf solution and your method is proven so it looks like the best choice in that regard, have my doubts about the rivet method only because of the wall thickness of the hollow rivet, the method i offered puts no strain @ all on the PCB. if OP sends me some of the inserts i pointed too i will gladly machine them to the size required.
    regards
    Mike
  1. Haunyang VFD input voltage
    By JamesUS in forum Spindles & Drive Motors
    Last Post: 18-01-2015, 08:25 PM
  2. Aluminum router build - Could use some input
    By Tumblebeer in forum Gantry/Router Machines & Building
    Last Post: 01-09-2014, 09:48 PM
  3. Stepper controller to manually input a specific degree
    By Web Goblin in forum Motor Drivers & Controllers
    Last Post: 13-10-2013, 05:47 AM
  4. Ok PCB milled now how to drill the holes ?
    By Fivetide in forum CAD & CAM Software
    Last Post: 12-05-2013, 08:31 PM
