    If your other dimensions are to within the tolerance of your machine, check the original vector you used for irregular transitions. It does not seem to be a backlash compensation issue because the other corners do not indicate it.
    https://emvioeng.com
    Quote Originally Posted by komatias View Post
    Hi thank you for your reply.
    The machine machined all the other areas ok not within spec but the radius generated were ok.How can i check for irregular transitions,Im not 100% on these types of machines.
    Luke
  1. G53 movement
    By Saracen in forum Programmers Corner
    Last Post: 05-02-2015, 07:58 PM
  2. axis movement jamming
    By Skydeals in forum Linear & Rotary Motion
    Last Post: 18-12-2014, 10:27 AM
  3. funny movement on solidcam turning
    By eamo1978 in forum Solidworks
    Last Post: 23-06-2014, 08:16 AM
  4. Z axis assembly - unsupported rail for very limited movement
    By dsc in forum Gantry/Router Machines & Building
    Last Post: 10-10-2012, 12:44 PM
  5. Motors, pulleys & movement - not strictly CNC related...
    By Rogue in forum General Discussion
    Last Post: 20-09-2011, 11:05 PM
