Thread: Wood Router, Snapping Cutters
13-09-2015 #14
I just got some of the 1/8" (3mm) dia. single-flute cutters from toolstation for cutting 9mm birch ply. I'll let you know how it goes. http://www.toolstation.com/shop/p67412
Before these, I've been using 3mm 2-flute solid carbide. I've cut for hours on end with no problems. I've run 13000rpm and 2000mm/min and also 18000rpm and 4000mm/min. Both 4mm DOC. http://www.ebay.co.uk/itm/5Pcs-3-175...item5422121974
However I wanted something with a thicker shank so I could extend it further out the collet for various reasons.
I've used spiral flutes but up-cutters leave a horrible finish on the top edge. Down-cutters make it difficult to leave a constant thickness skin on the bottom cut to maintain vacuum.Last edited by Tenson; 13-09-2015 at 11:40 PM.
Feed Rates and cutters for wood panels
By jimbo_cnc in forum Woodwork DiscussionReplies: 49Last Post: 12-03-2015, 04:24 PM -
router cutters for 2D/3D
By Skydeals in forum General DiscussionReplies: 5Last Post: 02-11-2014, 02:02 PM -
Router bits cutters for the Kress 1050
By Skydeals in forum Kress Milling MotorsReplies: 2Last Post: 28-10-2014, 09:25 PM -
TCT Router cutters in a mill running at 4000 RPM
By suesi34e in forum Tool & Tooling TechnologyReplies: 20Last Post: 26-02-2014, 08:02 PM -
Router Cutters
By sfallan in forum Tool & Tooling TechnologyReplies: 20Last Post: 26-08-2011, 09:23 PM
