21-09-2015 #7
This machine is absolutely unsuitable for any metal (unsupported rails on XYZ and most likely timing belts for AB -> by far not enough stiffness).
For aluminum you may be able to build a small 5 axis machine from $10000 upwards - for steel at least double that number.
But mechanics are only one issue - software is another:
- "Cheap" 5 axis software starts at about $5000 (I'm not joking).
- Even if you manage to get a copy of such software it will be useless because you need someone to program a post processor for your machines kinematics.
- Don't expect this kind of software to be easy to use - even CNC programmers with years of experience usually need to visit expensive training courses to use those programs.
5 Axis machining is absolutely out of reach for any hobbyist and even most businesses.
By the way: the part you've shown is possible with 3 axis as far as I can see - you just need to flip it once.
But even for just 3 axis you won't be able to find a machine with the ability to machine steel for just £1000.
ChristianLast edited by Christian Knuell; 21-09-2015 at 11:34 PM.
2D / 3D CAM Software and CNC controller: http://www.estlcam.com
FOR SALE: CNC 4 axis Foam Cutting Machine
By Am1707 in forum Items For SaleReplies: 1Last Post: 25-06-2015, 01:43 PM -
New machine Z axis
By Web Goblin in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 09-06-2014, 06:08 AM -
CNC machine "Spanish" model . Advice and opinions needed!
By shapebusters in forum Machine DiscussionReplies: 17Last Post: 12-03-2014, 06:21 AM -
Your views and opinions on the Black Cat CNC Machine 600x900 please
By Rockeyes in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 31-05-2012, 05:21 PM -
Opinions sought on cheap desktop PCB milling machine
By ksangeelee in forum Milling Machines, Builds & ConversionsReplies: 55Last Post: 16-03-2012, 01:57 PM
