    Lives in Marple Stockport, United Kingdom. Last Activity: 15 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    It also depends if it is 32bit or 64 bit syatem
    Given that parallel ports are not supported under 64 bit then external motion controllers would be the only option in 64 bit, Mach3 still works under 64 bit though
    - Nick
    Takes me back...
    C:\>debug
    -d40:0
    0040:0000 F8 03 00 00 00 00 00 00 - 78 03 00 00 00 0B 02
    -q
    C:\>
    Meaning one serial port at 03f8h and one parallel port at 0378h so if you wrote to 0378h your data would be on the pins in microseconds if not faster.
    Of course you were supposed to access it via the BIOS, not that that would slow it down much.
    It only really goes tits up when writing to 0378h causes an interrupt that will join the queue to sort the mess out at some nebulous time in the future.
  1. Mach3
    By petesos in forum Artsoft Mach (3 & 4)
    Last Post: 23-10-2012, 10:18 PM
  2. Mach3 and LCD
    By dzero in forum General Electronics
    Last Post: 30-07-2012, 12:50 PM
  3. mach3 goes off the bed
    By swinds in forum Artsoft Mach (3 & 4)
    Last Post: 17-01-2012, 11:43 PM
  4. mach3
    By edgas10 in forum Artsoft Mach (3 & 4)
    Last Post: 27-04-2011, 11:18 PM
  5. MPG and Mach3
    By GeoffV in forum Artsoft Mach (3 & 4)
    Last Post: 08-10-2010, 05:56 PM
