  1. Quote Originally Posted by pjm View Post
    Howdo,
    I have had similar issues with my Yakasawa VFD driving a small 3/4HP 3-ph motor. The issue was caused by the EM crud being emitted from the mains wiring out of the VFD. To cure the fault, I used a mains EM/RFI filter similar to ebay 161015962556 - mounted directly at the terminals of the VFD with only a couple of inches of mains wiring. The other thing that helped was the use of shielded 4 core cable up to the motor, with the shield being grounded at the VFD end only.
    I hope that helps!
    regards,
    Paul.
    What if stepper cables were 4core shielded?
    Would that help?
    Would You need to use shielded cable for spindle as well?
    Quote Originally Posted by Doktor View Post
    Would that help?
    You do realise this post was from 2013.!!!
    Slow broadband
  4. Quote Originally Posted by cropwell View Post
    Slow broadband
    ... and nevertheless there's still activity on this thread. If I wait for 2-3 days maybe someone will actually respond with something constructive.
    Why don't you start a new thread with an actual question. If you have problems with interference, you will get a better response if you detail the issues and ask for advice. I am sure that Lee would agree that this is the best approach to take. If he doesn't, he will voice his disagreement and correct my assumptions.
    The gist of this thread was to encourage CNC builders to keep wiring neat, properly earthed and appropriately shielded. Yes, shielded wiring to the steppers will be a good thing, but should really not be necessary if your control electronics are properly designed and installed. VFD's and steppers produce EMI, but it ought not to interfere with anything in a grounded metal control box.
    You will find members of this forum knowledgeable and willing to help and although some take the piss a little, the forum is generally friendly and you get good advice.
    I am the joker in the pack
    Rob 'Doc' cropwell
    Doubt it because it doesn't read like a question and more like a suggestion.!! . . . . . Rob was having a Joke but seems a sense of humour is in short supply these days.!!
    Rob I'm sure Lee would approve because your name doesn't start with "J" or "D" . . .
  2. Replies: 0
    Last Post: 13-11-2013, 07:50 PM
  3. Has anyone used these steppers or drivers?
    By Jonathan in forum Stepper & Servo Motors
    Last Post: 24-03-2011, 02:24 PM
  4. Emco 5PC steppers
    By Ian Hart in forum Stepper & Servo Motors
    Last Post: 26-02-2010, 02:47 PM
  5. Mariss Freimanis Steppers vs Servos Advantages/Disadvantages of both
    By Lee Roberts in forum Stepper & Servo Motors
    Last Post: 02-10-2007, 09:08 AM
