06-11-2015 #1
I have a Chinese motion controller for my cnc, which has been Ok, but does have issues (but rarely).
So I want a better quality motion controller but not top of the range expensive kit.
I came across these which seem to be reasonably priced. (more exp from CNC4you)
Anyone have any exp with these ?
http://www.cs-lab.eu/en/produkt-18,2...onnectors.htmlLast edited by dudz; 06-11-2015 at 10:39 PM.
Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
06-11-2015 #2
Yes I've fitted loads of them and they are top notch piece of kit.
Only down side to the IP-M is if you need slaved axis then it doesn't home to independant Home switches for each motor but other than that they are excellent with industrial quality and bullet proof 24v I/O and built in speed controller. Best of all they remove the need for a BOB which can't be under estimated what an advantage that is.
Software and support is top notch has well.
I only try to use Cslabs controllers these days when building machines if the budget can run to it and even then I'll sometimes Trim else where to make it so can use if doesn't.!. . . . Recommended it in a heart beat.Last edited by JAZZCNC; 06-11-2015 at 11:01 PM.
06-11-2015 #3
Having just converted my Chinese 1325 from DSP to MACH3 and the CSLABS IP-S (with much help and advice from JAZZCNC) I would heartily recommend the CS-labs kit. Like having a new machine
07-11-2015 #4
Good to hear.
My PC sometimes freezes in the middle of a job and the motion controller rarely but however does loose communication with the PC, causing unexpected stops. So I need to replace both the motion controller and the PC.
07-11-2015 #5
I bought a gigabyte brix compact PC that I have mounted inside the control cabinet, very compact and does the job very well, very low power usage as well.
07-11-2015 #6
Just had a look at them. Good idea, but more exp than normal used towers eh ?
07-11-2015 #7
Mine cost me 180 Euro with 500gb HD and 4GB ram. didn't think it was too bad, only uses 11watt of power in standby as well. Doesn't come with OS though. (nice avatar by the way, is that your bike?)
07-11-2015 #8
08-11-2015 #9
Here's the spec of the PC
Brand Gigabyte Item Weight 1 Kg Product Dimensions 19 x 16.6 x 8 cm Item model number GB-BXBT-2807-500/4 Series GB-BXBT-2807 Processor Brand Intel Processor Type Celeron D Processor Speed 2807 GHz RAM Size 4 GB Computer Memory Type SODIMM Graphics Card Description Intel HD Graphics Operating System None
More than enough for running MACH3.
10-11-2015 #10
Ok. Just ordered an IP-M
USB/Ethernet controller for Mach3/4 advice
By paulus.v in forum Control Hardware & SystemsReplies: 17Last Post: 17-02-2015, 09:37 PM -
FOR SALE: Galil 1880 8 axis PCI motion controller
By Boyan Silyavski in forum Items For SaleReplies: 1Last Post: 03-06-2014, 07:39 PM -
eBay: Galil DMC-1580 Motion Controller 8-Axis
By Boyan Silyavski in forum Items On eBay UKReplies: 1Last Post: 25-12-2013, 10:30 AM -
CSMIO/IP-M vs Ethernet SmoothStepper (Begone foul parallel port!)
By Greeny in forum Control Hardware & SystemsReplies: 20Last Post: 14-11-2013, 11:59 PM -
USB and Ethernet Mach3 motion controller PLCM-E3
By Purelogic R&D in forum Manufacturer NewsReplies: 39Last Post: 29-12-2012, 09:38 AM
