20-12-2015 #6
Based on the fact I know steve is running Mach3 then If your running an external motion control card you'll be much safer than running parallel port driven machine.
PP based can't afford for any interupts from the system and Internet can be problem, esp if machine is low spec or tuned on the high side so PP is working hard.
In all cases it's a little like playing russian roulet you never know when you'll get the bullet.!! . . . Often machien will give blip and the mistakenly gets blamed on something else when it's the Tinternet that did it in the background.!!
My suggestion is to turn off the Wifi while cutting and then turn back on if you need to make changes to Cam.
CNC - What Software
By g6uwi in forum Milling Machines, Builds & ConversionsReplies: 1Last Post: 10-04-2015, 08:27 PM -
Stuga routermaster problems computer dont seem to be connected to machine
By aled in forum Milling Machines, Builds & ConversionsReplies: 7Last Post: 16-01-2013, 04:11 PM -
Newbie. Questions about design software and machine control software
By MTech in forum Computer SoftwareReplies: 2Last Post: 11-12-2012, 12:58 PM -
RFQ: Custom CNC work - Just wondering how much...
By Mustang80 in forum Projects, Jobs & RequestsReplies: 0Last Post: 02-10-2011, 07:53 PM -
RFQ: Wondering if it's possible to get these CNCd and looking for a quote
By steventhebrave in forum Projects, Jobs & RequestsReplies: 7Last Post: 07-12-2010, 03:45 PM
