    Quote Originally Posted by Noplace View Post
    guys quick question, if I decide to get the CSMIO-IP-M with leadshine EM806, do I have to use resistors to limit the current of pul/dir signals? it is mentioned in the driver document but is it really necessary since output is so low from the CSMIO?
    I've got this controller with am882 drivers. If the am882 step and direct ports are featured with 5v then the datasheet says no resistors are needed, and on the csmio-ip-m it's says somewhere in the manual that the step and direct outputs are at 5v so I've not installed and resistors.
    Quote Originally Posted by Gotty101 View Post
    hmm ok so it outputs 5V for step/dir signals but 24v for other I/O ? I guess that works out but I quickly glanced at the manual it does say 5v but not exactly being direct about it. I heard it mentioned in the forums that the CSMIO has advantage of everything running at 24v so I assumed the step/dir was at 24v as well
    thanks for the info!
    Lives in Plymouth, United Kingdom. Last Activity: 20 Hours Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    I'm not sure that only being 5V matters too much in this case. Connections will be short inside the control box, and if you use twisted pair and differential connections there is a pretty high degree of noise immunity anyway. You will be using differential connections?
  4. The Following User Says Thank You to Neale For This Useful Post:
  5. #4
    Didn't see the other posts answering the question but just to back up what neale says about being 5v. The Cslabs are by far the best controllers I've used when it comes to noise immunity and by some way. Not many controllers can handle working along side high frequency devices like TIG welders but these do without any sign of trouble.
    Wiring with differential connections is essential to give you best protection so makes sure you do.
  7. #5
    will do, once I succumb to purchasing it haha , thanks all.
  8. #6
    I have an Asrock Q1900M with celeron dualcore prozessor afaik
    2Ghz and 2GB DDR3 Ram, because the board should only control the machine, I have added a 64GB SSD. the board only needs 10W and the SSD nearly nothing, the big advantage is, a SSD can't be damaged as easy as a HD.
  1. USB/Ethernet controller for Mach3/4 advice
    By paulus.v in forum Control Hardware & Systems
    Last Post: 17-02-2015, 09:37 PM
  2. FOR SALE: Galil 1880 8 axis PCI motion controller
    By Boyan Silyavski in forum Items For Sale
    Last Post: 03-06-2014, 07:39 PM
  3. eBay: Galil DMC-1580 Motion Controller 8-Axis
    By Boyan Silyavski in forum Items On eBay UK
    Last Post: 25-12-2013, 10:30 AM
  4. CSMIO/IP-M vs Ethernet SmoothStepper (Begone foul parallel port!)
    By Greeny in forum Control Hardware & Systems
    Last Post: 14-11-2013, 11:59 PM
  5. USB and Ethernet Mach3 motion controller PLCM-E3
    By Purelogic R&D in forum Manufacturer News
    Last Post: 29-12-2012, 09:38 AM
