    I've been resisting the temptation to buy one of these for a while:
    http://www.ebay.co.uk/itm/1000W-ZVS-...4AAOSwcu5URhOk
    Perhaps I should stop resisting....
    I gather that you've used the annealing method yourself - how did you heat the ballscrew, and do you think that there was any distortion? Was it machined out if so? I now have a lathe with a big enough spindle clearance for ballscrew machining, and trying to make sense out of the various sources of "advice" available via Google...
    There are some pictures of one I did here - got a bit carried away with the heating, but I didn't notice any distortion - neither did I check carefully if I'm honest.
    http://www.mycncuk.com/threads/4497-...0297#post30297
    I used my Mum's cooker to heat it - it's a gas hob. Better off using something with a bit more power output though.
  1. Best place for hard stops?
    By mitchejc in forum Gantry/Router Machines & Building
    Last Post: 25-11-2014, 06:39 AM
  2. site setting fairy hard at work again?
    By m_c in forum General Discussion
    Last Post: 21-05-2014, 04:53 PM
  3. RFQ: Why is it so hard...
    By ktc in forum Projects, Jobs & Requests
    Last Post: 11-08-2013, 08:05 PM
  4. How hard is it to make diy PCBs if you’re a Noob ?
    By Fivetide in forum General Electronics
    Last Post: 05-04-2013, 12:10 PM
  5. RFQ: Hard colour anodising
    By Mixster in forum Projects, Jobs & Requests
    Last Post: 11-03-2013, 10:58 PM
