Thread: E-Stop input problem
20-02-2016 #3
Presume you've tried changing the active state.?
Have you tried just putting a jumper wire across pin12 to gnd. This should allow mach to reset and eliminate any wiring issues. If with wire mach doesn't reset then change active state of pin 12 and try again.
New build – input/comments appreciated
By ngundtoft in forum Gantry/Router Machines & BuildingReplies: 73Last Post: 05-10-2015, 11:38 AM -
Help re electrical input
By Jomach21 in forum Motor Drivers & ControllersReplies: 1Last Post: 08-06-2015, 12:30 PM -
Haunyang VFD input voltage
By JamesUS in forum Spindles & Drive MotorsReplies: 0Last Post: 18-01-2015, 08:25 PM -
Aluminum router build - Could use some input
By Tumblebeer in forum Gantry/Router Machines & BuildingReplies: 17Last Post: 01-09-2014, 09:48 PM
