    Ey up chaps, I'm stuck.
    I have got a very old version of AutoCAD loaded on my CNC computer, which has no unnecessary software (networking etc), so the easy way of explaining my problem is to start with a photo of the screen
    What I am making is a harmonica case. The inside cutout is two rectangles and two circles. I want to end up with a pocket which is the combine of the four shapes. I can do the drawing in Coreldraw, and weld up the shapes, but when I transfer it to the CAM program (EstlCam) it produces a very 'steppy' outline, which is no use. I have to export the drawing to a .dwg file with Corel and then open it in AutoCAD and export it as a .dxf file to go into Estlcam. Somewhere in this process it loses the continuity of the shape.
    How do I make the four shapes into one outline ?
    I must admit that I do not understand the AutoCAD terminology. The program was bought for my son when he was a student in the late 1990's and I am unwilling to spend money on a CAD program, when there are so many free ones about and I am unlikely to use them to any worthwhile extent.
    Cheers,
    Rob
    Sorted - after a lot of messing about !
    iirc you type in the word TRIM :D
    Hi, sorry I meant to PM you!
    I have got past the stage of creating the shapes I need. Now I find I can't make them into a dxf file to put into my CAM program. All I get is the outer rectangle. I attach a copy of the dwg file, if anyone can help. The inside shape was created as a REGION and then made an outline with the UNION command.
    Here's the dwg file hc2.dwg
    Lives in Marple Stockport, United Kingdom. Last Activity: 17 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Rob are you trying to convert it to DXF if so here it is
    Rob.dxf
  7. The Following User Says Thank You to Clive S For This Useful Post:
  8. #7
    Thanks Clive, but I was hoping to find out why I could not do it, What the Fun was I doing that the export command did not pick up the inner bit?
    I need to know so that I can do other drawings through the same process.
    Cheers,
    Rob
  9. #8
    Rob was load it into Acad and saved as dxf in your version.
    I don't understand why it does not do that for you.
  10. #9
    Maybe because I have a very old version of AutoCAD (R14). It only gives me the .dwg or .dwt option on save as. DraftSight does not export the file either. I thought it might be because I had to create a REGION to combine the shape and this put it on another layer or something.
    I tried 'Save As' .dxf in DraftSight and that did not work properly as well.
    I reckon it is because I feel knacked at the moment and everthing is working to Sods Law. If I have a fresh go at it over the weekend, I might see what is happening.
    Cheers,
    Rob
  11. #10
    I tried importing Corel to AutoCAD and it was exceedingly messy, Instead of lines and arcs I got some bizarre Bezier shapes the AutoCAD could barely understand and I did not like at all.
  1. a little more help needed
    By terry1956 in forum Motor Drivers & Controllers
    Last Post: 29-02-2016, 05:52 PM
  2. 3d AutoCad CNC machine parts.
    By jcb121 in forum Open Source Designs & Plans
    Last Post: 09-10-2014, 10:18 PM
  3. Replies: 8
    Last Post: 01-02-2014, 09:33 AM
  4. Concentric reducer in autocad
    By Web Goblin in forum Computer Software
    Last Post: 24-09-2012, 03:58 PM
  5. AutoCad 2007
    By D-man in forum CAD & CAM Software
    Last Post: 05-08-2012, 05:51 PM
