Thread: Recommendations for Z Axis?
21-07-2016 #4
I know you asked about Z axis, but I would not use that design for the gantry sides. That I-beam is very weak when used like that and it will just twist the flange for loads in the Y direction.
I would plate over at least one of the sides to create a box section. You could do this by extending the existing end plate on the end of the main beam so it reaches the bottom of the I beam (lower flange) and joining them.
I-beams can be used for the gantry sides but they need to be orientated so that the flanges are pointing up/down (not fore/aft) and the central web runs inside to outside.
So in top view it would look like this:
Breakout board recommendations
By GND in forum General ElectronicsReplies: 15Last Post: 15-07-2015, 07:24 PM -
Concertina Axis covers..Recommendations please
By Nthkentman in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 07-04-2015, 09:43 PM -
Paint strippers - recommendations
By dsc in forum General DiscussionReplies: 10Last Post: 12-03-2015, 12:13 AM -
WANTED: 3-Axis Mill recommendations
By TomB in forum Items WantedReplies: 0Last Post: 05-10-2012, 10:06 AM -
CNC Lathe recommendations?
By UltraMagnus in forum Lathes, Lathe Rebuilding & ConversionsReplies: 0Last Post: 07-09-2011, 08:51 PM
