Finally had a bit of success using the pressure tank - it still leaks but using the compressor as a remote tank keeps it topped up for long enough to do its job. Bubbles sufficiently minimised - well , I can't see any... It's still important to prod the epoxy into the nooks and crannies - the pressure won't force the epoxy into any left-over voids in corners, as I discovered on an earlier test piece.
ID:	19104 Click image for larger version.
ID:	19105 Click image for larger version.
The MANTIS badges have been belt-sanded flush, I did attempt to polish one of 'em but the finish was rather patchy - heh - it's difficult to get a decent consistency across a larger surface using small mops on a press-drill... smaller stuff (like the skulls) come out a treat, though.
Wal.
