Thread: Bridgeport servo motor selection
You are a rich person. For that money you will buy 3 motors and drives from BST Automation (800euro), plus Servo motor for the spindle (450euro) so you could rigid tap, then buy (700euro) controller copy from Aliexpress -Newkye , pay 250 euros for DHl and even pay your duty tax and still half from what they want
15-10-2016 #2https://emvioeng.com
15-10-2016 #3
They sell 2.3kw servo motor for that money if sb feels like fiddling. Though i have read that VFD and encoder also could do the trick. I just sait its cause i saw the big motor for that money. Anyone should check if this is specifically possible due to shaft sizes, length, etc. Anyway, for me anything is possible if i put my mind on it. There is always a way
15-10-2016 #4https://emvioeng.com
15-10-2016 #5
I was really looking for the sizing information. They are suggesting that a motor sizes of 1.5kw are optimum wheras most on this website suggest 750w. Are BST good quality, i noticed the panasonics for about £500. Is the 700 euro a copy of the gsk?
Thanks for the reply.
15-10-2016 #6
Collin,
I am pretty sure the 750W is enough since you are going to gear it. The 1.5kW however for $90 is not a bad deal. I know that GSK controllers and Servos work well together and you will get decent support for them.
Just be warned that the 980MDc and any 980 for that matter requires a bit of ladder tweaking and macro writing if you are planning to use repeatable Z tooling like the stuff I sell.https://emvioeng.com
02-01-2018 #7
I did my BP conversion just over a year ago, all motors etc from BST on Aliexpress, great guy.
I used 750W AC servo with 2:1 reduction on X & Y, 400W with 2:1 reduction on Z, I still have not even made these motors warm up yet, I doubt a Bridgeport is going to be able to take a big enough cut to even bother a 750W motor.
My spindle is a 3kW investor rated motor, not a servo but I added an encoder and can do rigid tapping very nicely at lower speeds. Top speed is 4000rpm, bottom without back gear is 300rpm.
I am just adding another 750W servo to the knee so i can send it tool length compensation and keep all the quill travel for the work.Last edited by Davek0974; 01-08-2019 at 04:03 PM.
22-11-2018 #8
22-11-2018 #9
Hi
no you do not need motors with brakes, just plain AC servo motors, I got mine on Aliexpress from China.
I do not have a list, sorry.
23-11-2018 #10
I found the AC servo motors 0.75kw 80ST-M02430 2.39N.M 3000rpm and Servo driver with Servo cable 80ST (750 W for XY and 400W for Z), the timing belt and pulley, I have the pc, what else do I need to make it work? Can you send me few pictures of your setup? My email is [email protected]
ThanksLast edited by jfroux_1; 23-11-2018 at 04:04 AM.
Bridgeport Servo Motors--Mach3 Compatible?
By JPB33 in forum Bridgeport Milling MachinesReplies: 18Last Post: 06-07-2016, 08:06 AM -
eBay: SEM SERVO MOTOR SEM MT30 U4-48, LAMBDA psu,s, 160v servo drive
By dazza in forum Items On eBay UKReplies: 0Last Post: 29-01-2015, 08:55 AM -
Motor and Drive selection
By Marlin in forum Motor Drivers & ControllersReplies: 3Last Post: 14-08-2014, 03:25 PM
