    I Emailed GSK in China for the cost of their GSK980MDc, 750w servo for x and y and 400w for the Z.
    They replied:
    Dear Colin,
    Thank you for your reply, please find in the attachment a kind of milling machine which regularly retrofitted with our CNC system, I am not sure if it is similar to your machine, the machine worktable size is about 1270*254, and travel is about 720*380*125. For this kind of machine, axis motor is driven by belt, we mostly use 6Nm motor for X/Y axis, and 4Nm for Z axis, in this machine Z axis motor is only driven the spindle sleeve up and down, the motor rating is smaller and without brake, if your machine Z axis is not like this, may will need motor with brake also.
    Shall I take reference of this motor rating for you or give as you asked as 750w motor? For your information, our axis motor of less then 1kW is same price as 1kW(4Nm, 2500rpm rated, 3000rpm max) motor.
    Regarding the CNC system solution, you can refer to the following CNC system package:
    GSK980MDc CNC system
    including:
    GSK980MDc CNC controller 1set (8.4 inch Color screen, USB interface, 41 input and 36 output for user define with built-in PLC)
    6Nm servo motor with drivers without brake 2sets (2500rpm rated, 3000rpm max. 5000ppr incremental encoder, 130SJT-M060D(A2))
    6Nm servo motor with drivers with brake 1set (2500rpm rated, 3000rpm max. 5000ppr incremental encoder, 175SJT-MZ060D(A2))
    Handwheel(MPG) 1set (On controller panel)
    Cables (5m) and accessories
    The price for the package is USD3600 FOB Guangzhou, China.
    The above package with 4Nm servo motor and drivers (2500rpm rated, 3000rpm max. 5000ppr incremental encoder, 130SJT-M040D(A2)) is USD90 less in price.
    The above package with 750w servo motor and drivers is USD90 less in price, same as 4Nm.
    The price of GSK980MDc controller alone is USD1800 FOB Guangzhou, China.
    I have read several posts where they have said 750w for x and y was the way to go whereas gsk are suggesting 1.5 Kw is best. Any comments would be gratefully received.
    Colin
    Lives in East Lothian, United Kingdom. Last Activity: 16 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    My interpretation of their reply is that they do a standard package with controller and three 6Nm/2500RPM servos for $3600.
    If you want smaller motors, reduce the price by $90.
    I probably wouldn't want to go any bigger then 1kw on a Bridgeport.
    You are a rich person. For that money you will buy 3 motors and drives from BST Automation (800euro), plus Servo motor for the spindle (450euro) so you could rigid tap, then buy (700euro) controller copy from Aliexpress -Newkye , pay 250 euros for DHl and even pay your duty tax and still half from what they want
    What spindle motor is that Boyan?
    https://emvioeng.com
    I was really looking for the sizing information. They are suggesting that a motor sizes of 1.5kw are optimum wheras most on this website suggest 750w. Are BST good quality, i noticed the panasonics for about £500. Is the 700 euro a copy of the gsk?
    Thanks for the reply.
    Collin,
    I am pretty sure the 750W is enough since you are going to gear it. The 1.5kW however for $90 is not a bad deal. I know that GSK controllers and Servos work well together and you will get decent support for them.
    Just be warned that the 980MDc and any 980 for that matter requires a bit of ladder tweaking and macro writing if you are planning to use repeatable Z tooling like the stuff I sell.
    Quote Originally Posted by komatias View Post
    They sell 2.3kw servo motor for that money if sb feels like fiddling. Though i have read that VFD and encoder also could do the trick. I just sait its cause i saw the big motor for that money. Anyone should check if this is specifically possible due to shaft sizes, length, etc. Anyway, for me anything is possible if i put my mind on it. There is always a way
    Commutation servos usually go to 3K rpm. Spindles should go to 6K preferably. Have you per chance found a VFD with encoder inputs or are looking to feed the signal back to the controller? The latter is potentially possible in Mach too, Novakon do that I think.
    Collin,
    I did my BP conversion just over a year ago, all motors etc from BST on Aliexpress, great guy.
    I used 750W AC servo with 2:1 reduction on X & Y, 400W with 2:1 reduction on Z, I still have not even made these motors warm up yet, I doubt a Bridgeport is going to be able to take a big enough cut to even bother a 750W motor.
    My spindle is a 3kW investor rated motor, not a servo but I added an encoder and can do rigid tapping very nicely at lower speeds. Top speed is 4000rpm, bottom without back gear is 300rpm.
    I am just adding another 750W servo to the knee so i can send it tool length compensation and keep all the quill travel for the work.
    My spindle is a 3kW investor rated motor, not a servo but I added an encoder and can do rigid tapping very nicely at lower speeds. Top speed is 3000rpm, bottom without back gear is 300rpm.
    I'd like to convert my BP into a CNC milling. I'm not sure what I need... should I take servo motor with break. Do you have a liste of everything you had to buy for your BP?
  1. Bridgeport Servo Motors--Mach3 Compatible?
    By JPB33 in forum Bridgeport Milling Machines
    Last Post: 06-07-2016, 08:06 AM
  2. eBay: SEM SERVO MOTOR SEM MT30 U4-48, LAMBDA psu,s, 160v servo drive
    By dazza in forum Items On eBay UK
    Last Post: 29-01-2015, 08:55 AM
  3. Motor and Drive selection
    By Marlin in forum Motor Drivers & Controllers
    Last Post: 14-08-2014, 03:25 PM
