31-10-2016 #11
Boyan don't get me wrong here I'm not trying to put you or the controller down here but this needs to be said and made clear for sake of others reading what you wrote and thinking it will work same for them when chances are it won't and here's why.?
What speed was the machine traveling when power failed.? The law of physics dictates that inertia will make the axis continue on for some unknown distance if travleing at resonable velocity. So unless you have absolute encoders or Glass linear scales on the axis you will have lost position.
Now in your case you have Servo's which more than likely will have incremental encoders which don't retain there position when power is lost so they have not had any affect on keeping position. These controllers Also don't have positional feed back so equally it has no Clue to where the axis was when power failed.
So the fact you got back into position as nothing to do with the controller and everything to do with the fact your using servos which can accurately home. Probably using the encoder if using index pulse for homing.?
Steppers or Servo if traveling at any resonable feedrate position will be lost if poiwer fails. The function of getting back into Exact position as nothing to do with controller and everything thing to do with the HOME sensing type, be that encoder index or Home Switch.
This is no different to any other Controller be that PC based or Stand alone. The only exception is if your Encoders are absolute type or have Glass linear scales in which case the Servo drives are doing the work not the controller.
CSLAB CSMIO/IP-M 4-axis Ethernet Motion Controller
By dudz in forum CS-Lab (CSMIO)Replies: 35Last Post: 02-01-2017, 01:27 AM -
FOR SALE: Galil Motion Controller - PCI DMC 1842 - four axes
By lateAtNight in forum Items For SaleReplies: 1Last Post: 24-06-2014, 03:41 PM -
FOR SALE: Galil 1880 8 axis PCI motion controller
By Boyan Silyavski in forum Items For SaleReplies: 1Last Post: 03-06-2014, 07:39 PM -
Advice please! JAF Motion Controller issues!
By Mark Chard in forum Machine Control SoftwareReplies: 0Last Post: 31-01-2014, 05:03 PM -
eBay: Galil DMC-1580 Motion Controller 8-Axis
By Boyan Silyavski in forum Items On eBay UKReplies: 1Last Post: 25-12-2013, 10:30 AM
